Old 02-23-2010, 12:33 PM   #1
Ottawa , ON
Lightbulb Anybody know if a black tank will fit in the gray tank space on my TT?
I have a '74 31' Sovereign, and it's still equipped with the original 10-gallon gray tank.
I could have easily answered this question last summer when I had the belly pan off and the black and gray tank support rails remade, but I didn't. I never thought of this then.
Here's my story:
I bought a new black tank for my trailer soon after buying it, because the OP told me that the one in it was damaged and leaking. As I discovered after having it opened up, it turns out that he was wrong, it's fine.
Now, I'm wondering if there is sufficient room and clearance to replace the original gray tank with the extra black tank I have.
Anyone know?
Old 02-23-2010, 03:04 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I know this isn't what you asked, however, if you are thinking about monkeying around with plumbing, why not just add a gray tank between the frame? I bet it would be less work and you would get more capacity.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-23-2010, 05:17 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hey Aage,
Would the frame on our '72 be the same as your '74? If you send me the diminsions of your tank, I can measure the frame sections for you to see if it would fit. I know we don't have a gray water tank, but the belly pan is still off of Little Girl, so I have access to the frame for measuring once the snow melts a bit.
Chris
Old 02-23-2010, 07:44 PM   #4
Ottawa , ON
Chris,
Good thought. I bet that the frames are the same, there doesn't seem to be too much difference through most of the '70s on the Sov.
I will measure the tank tomorrow and let you know.
Great idea!
Rodney,
Another good idea! I'm wondering if the welder/frabricator that repaired my waste tanks last fall kept a note of the dimensions...? I'll give him a call 2morrow.
Thanks!
Old 02-23-2010, 09:36 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Anyone know?
Aage, one problem I see with this idea is that the Black Tank has a nice big hole in it for the toilet flange. What are your plans to deal with this hole?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-23-2010, 10:30 PM   #6
Ottawa , ON
OhhhhHhhhhhh.... yeah... Gonna think on it summore, but I think you came across a stopper there, Mike.
But thanks.
Old 02-24-2010, 06:37 AM   #7
Minno's Avatar
1972 31' Sovereign
Reducers? And then use it as a vent or inlet from one of the gray drain lines? Or cap the hole? Is the hole threaded? Just throwing out some ideas...
Old 02-24-2010, 06:55 AM   #8
Minno's Avatar
1972 31' Sovereign
This might help. I had taken measurements for a gray tank last Fall. The word "seam" indicates where the plywood floor is seamed together with splines.
Old 02-24-2010, 10:39 AM   #9
Ottawa , ON
Chris,
Thanks for the thoughts on how to make it go. There is of course a hole for the vent in the black tank, and yes, the "input" hole (toilet connection) is on the top, and is threaded to accept the flange. The existing holes would be difficult to use though, due to where they are.
I think I'd have to be at the trailer to see how it all would fit, but it looks like there would be an interesting amount of plumbing to do. According to the the image I posted below (scanned from my 1974 Service Manual), there is a lot of plumbing and tank connections in the rear of my TT!
As you can see, the gray tank is smaller, and is directly beside the black one, with both tanks oriented length-wise front to back. They are drained by one 3" pipe that connects them together, and of course, two waste gates.
Just for your interest, here is the arrangement for the mid bath trail, same size, same year. Much simpler, huh?
I'm wondering if your '72 Sov is a mid-bath, or is it just that they turned the black tank sideways when there was no gray tank to fit in the rear bath model, Chris? I can't tell from the image of "Little Girl" that you kindly posted.
FYI, I took some rough measurements of my extra black tank, and it is 5 3/4" tall, and at the support lip that surrounds it, 42˝" long and 30" wide. The lip is one inch all the way around.
More to think over, but I'm beginning to wonder if this is a project worth doing.
Old 02-24-2010, 04:13 PM   #10
Minno's Avatar
1972 31' Sovereign
Wow - quite a difference from my ‘72 to your ‘74. Mine is a rear bath, and as you can see, the plumbing is set up quite a bit different. I would hesitate trying to go by my frame dimensions after seeing how your tanks are orientated. At 30” wide, I doubt you could fit it in between two cross members and add it as a second gray tank. It would not fit in between the cross frame members of my ‘72. Perhaps a better option would be to buy a new tank that would fit in between the frame cross members forward of the current tanks, and then tying it into the current gray tank.
Chris
tank
Gray/black tank hookup Apache_Camp All Argosy Trailers 4 10-03-2009 06:54 PM
Gray and Black Water Tank Skycop Waste Systems, Tanks & Totes 9 07-24-2009 06:51 PM
Black and gray water tank Judy Barde Waste Systems, Tanks & Totes 11 12-11-2006 12:43 PM
no gray or black water holding tank pahadley LP Gas, Piping, Tanks & Regulators 8 11-11-2004 07:11 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
