Old 06-02-2008, 12:09 AM   #1
1966 26' Overlander
Show Low , Arizona
Unhappy Any Hope for this thing??
Started work on the black water tank today on my '66 Overlander. The threaded fitting for the flange is history (coudn't tell that it was threaded). So I cut it out.Click image for larger version
ID:	61599Click image for larger version
The dump valve bracket is welded into the tank and it was broken too. So I cut it off.Click image for larger version
I looked at plastic welding threads (too late), but I'm thinking with all the adhesives available there may be some way to save this mess.
Goy any ideas?
Chris
cem2525 is offline   Reply With Quote
Old 06-02-2008, 01:17 AM   #2
Originally Posted by cem2525
Started work on the black water tank today on my '66 Overlander. The threaded fitting for the flange is history (coudn't tell that it was threaded). So I cut it out.Attachment 61599Attachment 61601
The dump valve bracket is welded into the tank and it was broken too. So I cut it off.Attachment 61600
Goy any ideas?
Chris
The failures are due to the type plastic used.
We have fiberglass replacement tanks.
Hey Now, I hope you all are well Human Member Introductions 3 08-18-2007 12:35 PM
I hope it's simple! pittsf Refrigerators 4 06-19-2007 03:37 PM
some needed help i hope toronto Member Introductions 3 02-27-2007 08:59 PM
Owner soon I hope Airhead360 Member Introductions 3 07-08-2006 04:17 PM
Bob Hope... canny_banjo_man Off Topic Forum 10 07-30-2003 01:43 PM
