Old 03-13-2007, 02:37 PM   #1
1973 31' Sovereign
Portland , Oregon
Images: 22
Any alternatives to standard plumbing vent?
After having resealed the plumbing vents on my 1973 and reflecting on the fact that I will have to do it again in perhaps a few years it occurred to me to wonder if there might not be a better solution out there. For one thing surely there must be some type of vent that has a lid on top of it rather than the vent being entirely open to the elements? It seems like with the right design and a lid that it should not be nessary to have a gasket that needs to be replaced from time to time.
So here is the question: Have any of you seen, or used an alternative approach for your plumbing roof vents?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 03-13-2007, 03:27 PM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Check Ventline web site..
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 03-14-2007, 11:36 PM   #3
32spar's Avatar
1967 26' Overlander
1968 22' Safari
1953 21' Flying Cloud
1979 28' Airstream Excella 28
Fort Worth , Texas
Send a message via Yahoo to 32spar
We used an inline vent that vents into the wall or through it. It has a diaphragm that opens and closes as needed. So far it has been great. We purchased it at Home Depot and installed it with multi purpose pvc cement. Good Luck.
32spar is offline   Reply With Quote
Old 03-15-2007, 04:51 AM   #4
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Plumbing Vents.
Malcolm
Hi Malcolm; What I used is a product of Camco. It is a high impact plastic that is UV stabilized and fits 1 1/4 to 2 3/8 diameter pipe. Before installing it
I have placed SS screen inside attaching it with 3M 5200 adhesive. Same was used to seal it to the shell instead of putty tape that comes with it.
3M 5200 is a great product for sealing any problem spots. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 03-15-2007, 06:28 AM   #5
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Vents
Our trailers are going into a holding tank and your house is going into a septic tank or sewer. In both you need at least one vent that is open to the atmosphere. The mechanical vents or air (admittance valves) made by different companies only let air into the system. These are there to prevent the trap from being siphoned or gurgling. The trap is there to prevent sewer gasses from coming inside. The vent open to the atmosphere allows for air displacement from the tank without this your system will bubble like trying to fill a bottle with a hose. Air admittance valves could be used to protect your trap seal in conjunction with a open vent but may not be necessary on such a small system. Phil
Phil Gobie is offline   Reply With Quote
Old 03-15-2007, 09:41 AM   #6
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
better design and quality
Malcolm:
Vents made for the marine world are generally of much better design and quality. You can check nearby suppliers out there on the West Coast or go to the West Marine catalog for ideas.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 03-15-2007, 10:21 AM   #7
Radman's Avatar
1972 27' Overlander
Monterey Bay , California
Images: 129
Vents
I have also been pondering this open to the world system. My 72 Overlander is gutted minus front end cap and floor. With that said, I thought upon reinstallation of vent pipes was to use something along the lines of the fridge vent cover only a smaller version. The rain water filling tanks inside doesn't appeal to me much. I found a little sparrow in my galley line. Poor guy. I am a couple months away from this part of the project. I would be most interested in exactly how you solve this funky design.
Radman is offline   Reply With Quote
Old 03-15-2007, 08:51 PM   #8
1973 31' Sovereign
Portland , Oregon
Images: 22
Is it the cyclone type with the small wind powered fan? That the only type I saw on the Camco site.
Malcolm
Old 03-16-2007, 05:32 AM   #9
boatdoc's Avatar
1973 Argosy 26
Malcolm
Hi Malcolm; No it is not, it is a standard vent. I would have given you a Camco # but I have thrown away the packing. If you cannot find it Pm me and I will get you the #. Thanks, "Boatdoc"
Old 03-16-2007, 12:38 PM   #10
1973 31' Sovereign
Portland , Oregon
Images: 22
Shower drain pumps and venting?
There are a number of different types of shower drain pumps that are designed to pump drain water into the holding tank. Many of the ones that I have seen in the catalogs are set up to permit more than one source of input. If the shower, bathroom sink and kitchen sink were all connected to a shower pump wouldn't that mean that no plumbing vent would be needed for the drains themselves? It seems to me that only a vent for the holding tank would be needed.
Does anyone reading this have experience with shower drain pumps? How noisy are they? Is it true that no drain vent would be needed? Is it also true that no traps would be needed at the sinks?
What do you think?
Malcolm
Old 03-16-2007, 01:10 PM   #11
1973 31' Sovereign
Portland , Oregon
Images: 22
Boatdoc,
I think I have found the type of vent you described from camco. I found it, of all places, on Amazon.com
Amazon.com: camco plumbing vent
The funny thing is that there seem to be several different prices for what apears to be the same product. At $5.40 even the most expensive version of it looks like a good deal. Does the attached photo look like what you have? It would be nice if it were available in silver or grey but I suppose it could be painted depending on the type of plastic. Did you leave yours white? Did you use the supplied screws or something else? Are they stainless?
I could not find where it says anything about the diameter of the base. It does look like it would be large ennough to cover an old style vent hole though.
Malcolm
Old 03-16-2007, 06:14 PM   #12
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
malcolm
yes you will need some sort of vent. when you dump your tanks there needs to be a rather large vent because the air rushing in to replace the draining water would vaccum out all of your p traps.
those camco vents are just cheap plastic and would degrade faster than the factory aluminum and neoprene gasketed ones.
i would stick with the originals and just plan on doing maintinence on them every 5 years.
john
you call them ferrets, i call them weasels.
Old 03-17-2007, 01:43 PM   #13
1973 31' Sovereign
Portland , Oregon
Images: 22
John,
Thanks for the feedback. I did not, however, mean no vent on the tank. I was just speculating if the drains from shower and the sinks themselves might not need a vent if they drained into a shower sump pump unit.
Malcolm
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
