Old 01-19-2015, 02:41 PM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Aluminum Black Tank
I am purchasing a 55 Flying Cloud which currently has no waste tanks. The first order of business will be to add an above floor black tank in the wet bath. Rather than purchase a plastic tank and build a plywood box over it, I am considering having an aluminum tank fabricated which will be strong enough to support the toilet with no "box" required. An added bonus is it will look nice and probably outlast the trailer.
Has anyone does this before?
Any drawbacks?
I will need three openings in the tank: a vent "stub", a 3" outlet and a 3" inlet. My plan is to use threaded pipe fittings for the inlet and outlet, into which I can thread the plastic closet flange and Valterra fittings.
Comments?
BambiTex is offline   Reply With Quote
Old 01-19-2015, 04:18 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Any thoughts of using stainless steel? Also thought of a tank monitor system? Overall I think it would hold up very well and is a great idea.
Silverflames is offline   Reply With Quote
Old 01-19-2015, 05:02 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Aluminum and human waste are not compatible with each other. The aluminum will corrode out in a very short amount of time. Stainless Steel would be a better choice. If it was mine I would use either ABS or Polyurethane, both would be a lot easier to deal with.
Old 01-19-2015, 06:16 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I hate to burst your bubble, but you may still need to build a box around it, unless you make it with very thick walls and top. The weight of the toilet, with a person sitting on it, will probably cause oil-canning (the roof of the tank flexes) as a person sits on it and then rises, thereby changing the weight the top of the tank supports. It would look (and weigh) like a miniature version of a pickup-bed toolbox in order to be strong enough to prevent oil-canning under a person's weight, and that's hardly attractive.
You really are better going with a plastic tank and building a wooden box around it. Wood is a lot lighter and more attractive than steel and can be made thick enough not to noticeably flex, without being too heavy.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-19-2015, 09:00 PM   #5
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
I built both a aluminum black and grey tank, mounted under the floor in our 31' 67. If you need to strengthen it you can gusset it inside. I completely drain both tanks when we are not using the trailer.
Rolland is offline   Reply With Quote
Old 01-19-2015, 10:20 PM   #6
1969 29' Ambassador
Aluminum Black Tank
Sorry kinda of dumb here. What does gusset mean? I assume it's a kind of reenforcement.
Old 01-20-2015, 06:33 AM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Tank fabricator would use 3/16" aluminum which he says is plenty stiff/strong enough for this purpose. He has been building aliuminum tanks for boats for 25 years.
Old 01-20-2015, 06:57 AM   #8
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
There is a lot of corrosion potential for human waste. Once the aluminum gets pitted, it's not going to rinse as clean. You could get a 2 part epoxy paint, then pour inside the tank and rotate it to coat the inside.
I did 1/4" black ABS myself, but it was below the belly. I did add tank washers. you may want to consider that, but possibly in a wet bath the wand washer is best.
robwok is offline   Reply With Quote
Old 01-22-2015, 06:36 AM   #9
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Ok, more research has convinced me that an aluminum black tank is a bad idea. I will get a plastic one and perhaps cover it with an aluminum box. Still thinking it will be above the floor but gray tank may go below....
Old 02-03-2015, 08:15 PM   #10
1969 29' Ambassador
Pics plz when you are done!
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
black tank and toilet flange; when is it necessary to replace the tank? Globie64 Waste Systems, Tanks & Totes 7 09-07-2011 04:04 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
Anybody know if a black tank will fit in the gray tank space on my TT? Aage Waste Systems, Tanks & Totes 9 02-24-2010 04:13 PM
