Old 07-29-2016, 01:53 PM   #1
Peterborough , New Hampshire
all water goes into black water tank?
I'm a nubie, I bought a 71 21' globetrotter not knowing a lot about them. I brought it right to my local guy and he went through the whole thing. I had a couple issues with the plumbing, minor really. So he said once he fixed the leak he found out the hard way that my shower and grey water run right into my black water tank and if it is full, it backs up into the shower! Is this right? There isn't a grey water tank? If so what is the solution?
terricrowe26 is offline   Reply With Quote
Old 07-29-2016, 02:20 PM   #2
nickclifford's Avatar
1972 31' Sovereign
felton , California
i made same mistake
had no clue that a trailer of my size could not have had a grey tank also. It was considered ok to run shower and sink water onto the ground in the 1970's I guess. Campsites would be a real mess if everyone did that. Anyway..you can run grey into the black but not advisable if using the black for #2 ... I'm going to install a composting toilet anyway, so hoping to convert black to accept grey water ...
nickclifford is offline   Reply With Quote
Old 07-29-2016, 02:31 PM   #3
billymyers56's Avatar
2016 28' Pendleton
Commerce , Texas
I have a 72 and it has no grey water tank.
billymyers56 is offline   Reply With Quote
Old 07-29-2016, 04:39 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One solution— install a Hepvo valve in your shower drain line. This will prevent an over-full waste tank from backing up into the shower. A Hepvo valve is a type of check valve that is installed in place of a P-trap, that blocks odors and back-flow of water. However, it's not infallible. If the shower runoff is what makes the tank overflow, then the weight of the water trying to drain out of the shower will hold the valve open. But black water would not flow from the tank to the shower pan, just the shower would not drain until the tank was emptied.
My Airstream Interstate has Hepvo valves on all sink drains and the shower drain, and they work well.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 07-29-2016, 04:46 PM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
We get this same question on the forum several times a week. No Airstream built before 1973 has a tank for sink or shower water. It drains through a pipe and out onto the ground, unless you cap the pipe. Then it backs up in the shower.
Old 07-30-2016, 04:57 AM   #6
Do you have any idea of the cost of switching to a compositing toilet and gray water tank? I would consider doing the same if possible. I mainly want to be able to take a shower after hiking.
Old 07-30-2016, 07:20 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would bet the termination cap was in place on the sewer line and the black water valve either leaks or was open in order for black water to enter the shower pan.
The black water valve should remain closed until you are ready to dump.
You can get what is known as a "blue boy" which is a portable tank that connects to the sewer dump, then use it for the grey water.
I would guess the black water tank has a 12 gallon capacity in your coach. The size of tote you get for grey water is your choice from 10 gallons and up.
Old 07-30-2016, 08:47 AM   #8
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
We had a '73 Sovereign. No grey water tank. '74 was the first year grey water tanks were standard on the Sovereign.
My daughter and son in law, current owners of the '73, have added a grey water tank and replaced the black water tank, which cracked and was starting to leak.
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 08-01-2016, 09:12 AM   #9
OK, my guy working on it, which he admittedly doesn't work on them much, looked for a way for the water just to drain out and couldn't find anything. He thinks it has probably been re-plumbed, UGH. What do I do now?
Old 08-01-2016, 12:13 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The grey water drains out at the same point as the black water. The difference is: the black water tank and line has a shut off to prevent the tank from emptying unless the valve is open.
On pre '74 coaches the grey water piping is connected to the sewer line downstream from the black water shut off valve.
An easy test short of tracing the lines from the bath and galley sinks is to close the black water valve. Remove the termination cap. Run water into one of the sinks and see if it comes out the sewer connection pipe.
Note : there is not a separate sewer connection for the grey water. Again it uses the same pipe to exit the trailer.
Old 08-01-2016, 02:48 PM   #11
1952 25' Cruiser
1967 22' Safari
1969 18' Caravel
Palo Alto , California
grey tank
The first two things you need to do when buying an old trailer is a) install a grey tank and b) replace the axle
markdenise is offline   Reply With Quote
Old 08-02-2016, 09:48 AM   #12
Thank you! That is exactly what I needed to know! I keep ready over the manual and the pictures and descriptions are not very clear to a novice. I am bring her back home Friday, I will try that this weekend. Thanks again.
Old 08-02-2016, 10:10 AM   #13
My guy that is working on it said someone re-plumbed it and there is no shut off valve anymore, the gray water runs into the black water tank and the toilet is disconnected. So how expensive and hard is it going to be to get this right? What would be the ultimate would be to have a gray water tank too but if I don't need to pull this camper apart I would prefer to just use a portable gray water tank instead. That is going to require re-plumbing so the gray doesn't run into the black. I am trying not to let this get to me to much!
Old 08-02-2016, 12:24 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you say the toilet is disconnected.
What does that mean?
Is the water supply disconnected from the toilet?
Is the toilet no longer sitting on top of the black water tank?
How does the grey water get into the black water tank?
Is the black water tank in this coach below the floor?
Can you post some pics?
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Electrical - this cord goes into a green box rollin home Electrical - Systems, Generators, Batteries & Solar 5 08-13-2009 11:29 AM
Furnace goes on, TV goes off whacksplat General Repair Forum 11 05-17-2009 07:33 AM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
