Old 07-25-2015, 08:41 PM   #1
1961 22' Flying Cloud
Parkville , Missouri
Advise please: removing Black Tank from 61 Flying Cloud
I'm trying to remove the toilet, platform and above-floor black water tank from my '61 Flying cloud.
The toilet came off without incident, but I'm not sure how to get the tank disconnected from the platform floor. I've unscrewed what appears to be a ring that holds the platform floor to the tank. But it's not easily disconnecting.
Can anyone tell me if the ring screws off (and therefore I need to use a bit more force to get it to unscrew), or is it connected in some other way that I just can't see.
I'm attaching a picture...
Also, if I get the platform floor unattached, will I be able to remove the black tank entirely? Or will I need to open the underbelly to disconnect it from below?
ID:	243899   Click image for larger version
kirkrik is offline   Reply With Quote
Old 10-21-2015, 01:09 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Given the age of this post, you have probably resolved this by now. Flange is probably threaded. Tank should be removable from above the floor.
BambiTex is offline   Reply With Quote
Yikes! Grey water tank leaking...please advise pamelake Sinks, Showers & Toilets 10 07-28-2014 03:46 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Removing water tank on 28' 2010 Flying Cloud?? Alphonse Fresh Water Systems 15 12-24-2013 10:37 AM
Need advise removing fuzzy ceiling carpet glue JoeF Member Introductions 6 10-24-2007 10:36 PM
Any advise on tracing either wbcci# or s/n '55 flying cloud jaynshae WBCCI Forum 1 09-11-2004 06:01 PM
