Old 03-13-2015, 07:04 PM   #1
iwbull's Avatar
1965 17' Caravel
San Francisco , California
Adding grey waste tank to 65 Caravel
I have a 1965 Caravel and I currently carry a blue-boy to capture grey waste water. For a variety of reasons I am considering having a grey tank added to the trailer. I have gotten a quote from my favorite Airstream guys of about $2k to install the tank and re-route the pluming and waste outlets. Their plan is to install the tank up in the frame and leave the black tank where it is.
My Question is what others think are the advantages and disadvantaged to this type of upgrade and is it worth the cost?
Ingall Bull
1965 Airstream Caravel
2014 Jeep Cherokee Latitude
V6, Tow Group, Comfort and Convenience Group
o)))))))o
iwbull is offline   Reply With Quote
Old 03-13-2015, 07:06 PM   #2
DFlores's Avatar
1968 22' Safari
The size tank you will install is probably 12 gal, or that's what fit in mine. Not sure it would be a $2k improvement
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 03-13-2015, 07:26 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I have two tanks in my frame that were purchased from Vintage Trailer Supply. They're tied together & hold a total of 32 gallons. The black tank is inside as designed. Here's the link for the tanks:
Gray Water Tank 50"
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-15-2015, 12:58 PM   #4
iwbull's Avatar
1965 17' Caravel
The guys that will install the tank say the waste outlet will hang lower then the black outlet does,currently. More akin to a modern Airstream. Has that been others experience?
I've heard of one example of where an installer separated the black and grey outlet. That does not seem like an arrangement I would want.
Ingall Bull
o)))))))o
Old 03-15-2015, 02:10 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Here is a picture of our plumbing for the grey tanks. To the left are the tanks (you can only see one, but the other is tied to this one through a pipe & rubber coupling). Then it ties in with the shower drain & runs to the main dump valve. Above the main dump valve is the black tank. They grey tank valve sits right next to the black tank valve & they both dump out of the same main valve, so you only need to put your slinky on once. Pictures explain it better:
The first picture is the valve that sits under the black tank (it sits with the white end under the black tank, so it's upside down in the picture). The curved pipe is where the grey comes in & there is a gang valve here.
Becky
1964 Bambi II
1988 Avion 32S
Old 03-16-2015, 06:13 PM   #6
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
My friend here on the sight,, "TG Twinkie" did is trailer with a 20 gallon holding tank under there bed.. I felt it was a slick idea and did it also with our 72 Overlander.. I think he posted his idea under his name over a year ago.
Total cost around $120..
We use a little 12v transfer pump and a ball valve set up to direct the water flow.. It sucks it out of the sink drain,, fills the tank and when time to dump just a matter of flipping ball valves and empty out the normal drain.
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 03-18-2015, 01:02 PM   #7
Rocker66's Avatar
1965 24' Tradewind
Henderson , Nevada
Nice job Becky - I'm getting ready to do the same thing and was wondering if you could post some pictures of where you mounted the dump outlet , would love to see how you tied it all together.
Where inside the trailer did you plumb into the gray tank ?
Does your toilet sit directly on top of the Black tank ?
Thanks in advance. JD
Rocker66 is offline   Reply With Quote
Old 03-18-2015, 01:32 PM   #8
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Added tanks
I am in the middle of this exercise on my vintage trailer.
I fitted a black tank above the floor and mounted a low profile toilet on top. I added a VTS 50 inch gray tank between the frame rails and connected both tanks to an existing vent stack. Shower drain connects to gray tank under the floor and both tanks connect to a sanitary collector with separate dump valves. Everything fits above the belly pan except the collector and gray tank valve, both of which will be protected by a hinged lid.
I tied the two sink drains together under the kitchen cabinet and ran the drain line into the top of the gray tank.
ID:	234477   Click image for larger version
BambiTex is offline   Reply With Quote
Old 03-18-2015, 07:44 PM   #9
Rocker66's Avatar
1965 24' Tradewind
Henderson , Nevada
What black tank model did you get ?
Old 03-18-2015, 08:19 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
The toilet sits directly above the black tank & dumps directly under the black tank. The grey tank is tied to the dump right next to the black tank. There is a black tank pull & a grey tank pull in the rear bumper.
The sink in the galley dumps into the grey tank & is vented, and the shower dumps into the grey tank & is vented through the same vent. I can't get into my trailer right now for pictures, but I'll try in the next couple of days.
Becky
1964 Bambi II
1988 Avion 32S
caravel
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Adding/added a grey tank? rayandre 1970 Overlander 3 08-12-2011 09:53 PM
Alternative to adding a grey tank, 60s rig eubank Waste Systems, Tanks & Totes 12 04-06-2011 02:54 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
1963 overlander - adding grey tank? bugdog Waste Systems, Tanks & Totes 11 09-03-2008 04:11 AM
