Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 01-24-2009, 12:35 PM   #1
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
Hi CV65
8 Gal is a pretty small tank. You will be emptying it frequently. You might take a look at my installation of a 23 gal tank if you don't mind the tank sticking out under the belly. Keep in mind that the tank doesn't stick out below the axle, so if you are going to bottom out with it, you are already in trouble!!
http://www.airforums.com/forums/blog...tallation-144/
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 01-24-2009, 02:10 PM   #2
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Grey tanks
Here is a good source.
RV Holding Tanks
As noted. you can also get big tanks that hang below the frame. Watch out here, however. They will drag on steep drives (gas station drives are the worst) and some installations open the belly to critters, cold air and moisture. The dump valves are the most common casualty.
Old 01-24-2009, 05:29 PM   #3
Profile:  1965 17' Caravel
Southern , Connecticut
Thanks, guys
Thanks for the ideas guys. I'll post back when we order them.
John
65CV is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 08:33 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 07:09 AM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 09:52 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 11:45 PM
