Old 05-16-2012, 08:24 PM   #1
bluemoontwo's Avatar
1958 18' "Footer"
San Luis Obispo , California
Adding Black Tank to 1958 Traveler
Our 1958 18' Traveler did not come from the factory with any holding tanks (besides a small fresh water tank under the bed). We want to add a black tank under the toilet, preferably under the subfloor. We saw gray water tanks for vintage trailers on Vintage Trailer Supply. They fit between the frame members which is great. Can this tank also be used for black water or are the two types of tanks shaped differently?
Thanks for everyone's help. We are learning a tremendous amount as we navigate through our restoration.
Forum Thread: The Chronicles of the Shiny Tiny
Happy to finally be part of the (t)in crowd!
bluemoontwo is offline   Reply With Quote
Old 05-25-2012, 09:21 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
The tanks are the same - until you've used it!
The only thing that might preclude you from putting it in the floor is if your toilet is in a "corner". At least with our trailer, the belly pan/banana wrap rolls up along the perimeter so the depth isn't there for the tank within the frame there. The tank would have to be way too shallow or wedge-shaped. Depending on which tank you are looking at, I think they are going to be deeper than your 1958 frame so they will need to either stick up or drop down anyways unless you have them custom made (we did because they weren't available at VTS at the time).
We opted for an above floor tank and a low-boy toilet. The toilet really should sit directly above the tank - while it doesn't have to be centered, you really don't want any horizontal travel which could cause blockage in the "poop-chute".
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
