Old 04-04-2011, 11:42 AM   #1
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
Adding a larger grey tank to a 78 Tradewind
I have a 1978 25 ft. TradeWind with the infamously small grey tank (like 12 gal. - rediculous!). I have recently dropped the belly pans because I had a split brake line that needed repair,,, and now I have removed the side wraps so I can wire brush and POR15 the frame as long as I am there..... And, since I am there, how about installing a bigger grey tank????? Madness.... just madness....
So, what's the easiest approach to adding more grey tank capacity?
I can add a second tank closer to the axles, but there are some drain pipe height issues to work out and, the existing grey tank will have to be replaced since I can't cut into it and I can't merge into it's discharge line.
Oh yeah, I also want to install a macerator semi-permanently.... there is just enough room for it, I think....
Does anyone out there have the drain pipe plumbing diagram from the service manual for a mid-to-late 80's, or 90's, 25 ft. TradeWind with the rear Shower Bath configuration? I am looking for ideas....
And, do I really need the foam pad under the tank? I am not winter camping (not using water when I do) and I will support the tanks independent of the bottom cover.
Thanks.
John H
johnhh is offline   Reply With Quote
Old 04-04-2011, 12:37 PM   #2
Ottawa , ON
Wow, you have a 12 gallon grey tank? That's luxury to me; ours is ten gallons!
It's my belief that you will need top access to change the tanks fabout, or just add a second grey tank because of the way the tanks are suspended on the frame rails. By that I mean remove lots of interior (oh NOO!)
But check with an expert: Member Colin H will know...
Old 04-04-2011, 12:42 PM   #3
1967 22' Safari
1978 25' Tradewind
I was being generous at 12 gal., you are probably right at 10 gallon. It's a damn small tank...
Top access is not what I want to hear. but no, no, no. The bottom is off, I don't want to be tearing out the inside...
John H
Old 04-04-2011, 12:43 PM   #4
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
John H,
I think you want to keep the foam pad. It will keep tank from shifting and chaffing, which will eventually lead to tank failure.
heslinhotel is offline   Reply With Quote
Add additional grey tank Breadbug Waste Systems, Tanks & Totes 4 04-05-2011 06:20 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
