Old 11-11-2010, 08:24 PM   #1
StPierre's Avatar
1965 22' Safari
Rescue , California
Adding a gray tank to a 65 Safari
I finially got the floor up and belly pan off. Now it is time for the gray water tank. Any suggestions on a tank? I have looked at the one at Vintage Trailer. However, as you can see my furnace duct system is in the way. I plan on using the same furnace as it is in excellent condition.
Any help and pictures would be greatly appreciated. Thank you.
ID:	115045   Click image for larger version
Name:	furnace duct on left.JPG
Name:	gray water location.JPG
The St Pierre's
StPierre is offline   Reply With Quote
Old 11-12-2010, 03:47 AM   #2
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Try ronco-plastics.com or rvsurplus.net .Ronco has a great selection and the people were great to do business with.The product is top notch and They gave me a great deal on 2 tanks.
bwaysteve is offline   Reply With Quote
Old 11-12-2010, 07:42 PM   #3
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Viking has a '64 Safari like me, and has a suggestion for a grey tank covered in this post here.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 11-13-2010, 07:03 PM   #4
StPierre's Avatar
1965 22' Safari
Rescue , California
What do you think of this? My plan is to have the gray tank drain to the rear of the AS, and the black tank drain to the front, with a side discharge to the street. Has anyone used this set-up?
Thanks for the feedback on where to get the tanks, I will be calling around to order this week.
The St Pierre's
Old 11-13-2010, 07:29 PM   #5
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Just installed back to front front to back,tested and works perfectly.I used matching Ronco R-17 tanks and ran the gray out reduced to 1 1/2 and streetside.Then used a street elbow andran to front.Back tank in usual place and gray in the first slot behind the last axle.I also bought a valve assembly 1 1/2 on one side and 3" on the other and it was adjustable to fit (Valterra)
I think I have pics up on the thread "Gutting th 65" Good Luck! Steve
Need advice on adding a gray tank. WILDRTEXAS Waste Systems, Tanks & Totes 2 01-21-2010 09:22 PM
adding gray water tank to 65 caravel joqin Waste Systems, Tanks & Totes 16 01-24-2009 04:29 PM
Adding gray water tank to a 1971 25' paul903 Waste Systems, Tanks & Totes 15 07-07-2008 09:44 PM
Adding a Gray Tank to my '72 Sovereign mello mike Waste Systems, Tanks & Totes 6 08-11-2004 02:50 PM
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
