Old 08-23-2013, 08:37 PM   #15
JT
El Paso , Texas
I added a 25 gal tank to our 27 ft 1973 rear bath and after plumbing to the rear dump and and to the original dump outlet have about 30 gal capacity. The gray tank was from PPI Motor Homes and is placed between the frame behind the axles and hangs down about 3" below the bottom of the trailer on one side and the 3" pipe also is below the bottom skin. You really don't notice it unless you get down on hands and knees. Both the gray and black tanks dump through the same outlet. We have used it for 3 years without a problem.
jimbob79 is offline   Reply With Quote
