Old 02-08-2011, 09:25 AM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
Add additional grey tank
Anyone know of a thread that shows adding additional grey tank to a Trade Wind? I'm curious as to how they routed the plumbing or any other mods to it.
Ed/Breadbug
Breadbug is offline   Reply With Quote
Old 04-05-2011, 09:29 AM   #2
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
Ed, I am thinking the same as you, adding a grey tank. Did you get any ideas from people?
Thanks, John H
johnhh is offline   Reply With Quote
Old 04-05-2011, 12:24 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I added a tank to my '68 Tradewind.
The solution I came up with was to junction the sinks/shower drain at the rear of the trailer and splice that to a length of flexible (2 inch?) hose. That hose was threaded through the main long section of the frame and from there to the new tank. The drain out of the tank is via hard PVC at the rear of the tank and to the rear of the camper where it is tied into a common final drain with the black water system.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-05-2011, 02:43 PM   #4
1967 22' Safari
1978 25' Tradewind
Rodney,
That's an interesting idea you have. Re-route the 1 1/2" pipes to the new tank. Replace the existing tank and connect it to the new tank with a 3" pipe connector, to both the new tank and the existing drain-out system. I could do all that from the bottom side and the sequence will give me access to all the pipes.
Nice idea to consider. Thanks. John H
Old 04-05-2011, 06:20 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We actually have two grey tanks (plus a black) in our '56 Safari. They are tied together and drain through one valve. Our set-up is probably different than yours though because we started off with NO TANKS so we could design ours from scratch. For more details, check out my "It's a Girl!!!" thread...post #261 shows them in place before the floor went down.
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
'75 TW fresh tank removal 1 man Breadbug Fresh Water Systems 4 02-01-2011 07:31 PM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 01:07 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
