Old 04-23-2012, 10:00 PM   #29
1973 25' Tradewind
Augusta , Georgia
Originally Posted by 62overlander
here is my new grey/ gray tank. It is right behind the axles and will be covered with an aluminum cover. Where it is, is not very noticeable at all. You actually have to look for it. It is 30 gallons and will have a 3" gate valve. I am also planning on fabricating some aluminum mud flaps to keep road debris from being shot up.
What are the dimensions of this tank? (make model would also be nice) I'm looking at holding tanks and was limiting myself to 5" thick versions. Been thinking about a thicker grey water tank and installing in similar fashion. A couple more pictures would be appreciated.
DGJackson is offline   Reply With Quote
Old 10-22-2016, 05:44 PM   #30
1961 28' Ambassador
Zionsville , Indiana
Malcolm,
I came across this old post while trying to decide how to set up my 61 Ambassador. What setup did you end up using? I have a blank slate to work with and want to maximize space.
Jordan
jbrown1961 is offline   Reply With Quote
Holding tanks eddo 1969 - 1973 Safari 8 07-01-2014 03:47 PM
Holding Tanks achip Waste Systems, Tanks & Totes 1 06-18-2006 05:28 PM
Fabricating extra space Devoman Exterior Storage Compartments & Access Doors 25 12-03-2005 04:20 PM
Holding tanks, need help twilder Waste Systems, Tanks & Totes 2 07-18-2003 04:02 PM
Holding tanks smallfry Waste Systems, Tanks & Totes 2 12-17-2002 02:17 PM
