Old 11-30-2009, 08:02 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
94 Excella Black Water Valve Replacement
Have a '94 Excella Limited with a leaking black water valve. Tried flushing, squirting and powdered lube but still won't close completely. Looks like a previouse repair too (panel cut out near valve location). Need a source for parts and tips on replacement.
Regards, Don Hetzler
Emh142 is offline   Reply With Quote
Old 11-30-2009, 10:39 PM   #2
casarodante's Avatar
2012 31' Classic
Here are a couple of threads to help.
http://www.airforums.com/forums/f444...pair-4753.html
http://www.airforums.com/forums/f444...nks-18469.html
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 12-01-2009, 08:34 AM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Suggestion:
Get to it, take it out, disassemble it, clean it.
There may be a bit of debris not allowing
it to seal off. Once you have it out, it only takes
a few minutes to disassemble.
kennethowens is offline   Reply With Quote
dump valve
Is there a black-water-tank valve? hagnik Waste Systems, Tanks & Totes 1 08-31-2009 07:18 AM
Black Water Dump Valve SJ Brown Waste Systems, Tanks & Totes 2 06-17-2009 07:24 PM
78 argosy minuet, black water discharge valve replacement argosy Chuck Waste Systems, Tanks & Totes 5 05-03-2009 04:59 PM
Sticky Black Water Valve squeeky Waste Systems, Tanks & Totes 3 04-09-2004 10:47 AM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
