Old 09-04-2016, 08:36 PM   #1
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
'88 Limited tanks
Which handle controls what? There are 2 handles. One before and one after the drain connect. Which one is grey and which one is black?
Cristobal is offline   Reply With Quote
Old 09-05-2016, 08:10 AM   #2
eubank's Avatar
1967 30' Sovereign
Bosque Farms , New Mexico
Sometimes hard to tell, huh?
Most times, a black valve will have a large pipe leading to it in order to carry, ah, er, clumps. A gray valve will have a smaller pipe leading to it. Alas, Airstreams are often designed so that you can't see the pipes.
Of course, you could dump a little into a bucket and examine the contents. And then slap a label on the valves.
Lynn
WBCCI 21043
Old 09-05-2016, 09:18 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On an 88 the black tank handle is on the right when you are facing the handles ready to open them.
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 09:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 09:25 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 01:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 12:42 PM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 09:34 AM
