Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-18-2010, 07:02 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
'87 Excella gray water tank release t-handle?
Hi all-
Dad's 32' Excella had the t-handle and wire locks for it sheared off (what a great place to put this fragile equipment: right behind the wheels!!). The t-handle attaches to a bent piece of aluminum tubing that attaches to the actual pull valve with a rivet.
We put a bolt into the end of the aluminum tubing to keep it in the proper position, but are wondering if it is possible to get this mechanism new? It is still possible to pull the mechanism and "dump" the gray water, but it would be better for Dad with his bad knees to be able to have the t-handle back in place.
Any ideas/leads appreciated. Ben
PA BAMBI II is offline   Reply With Quote
Old 08-18-2010, 07:16 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
They still have them at Inland RV.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-19-2010, 05:37 AM   #3
1964 17' Bambi II
1961 24' Tradewind
Red face
I have contacted Inland RV and awaiting a response. I saw they have one pictured that looks right, but it is straight. Is this something I will have to bend, or will they have the correct alignment as well?
Thanks much! Ben
Old 08-19-2010, 06:03 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
On my '86, the piece of metal that the straight t-handle slides into is also straight. Did yours get bent perhaps?
Becky
1964 Bambi II
1988 Avion 32S
'81 Excella II Gray Water Tank Removal boo_n_sue Waste Systems, Tanks & Totes 3 08-08-2010 09:06 PM
Gray water Tank CJ of Okla Waste Systems, Tanks & Totes 10 08-09-2008 10:01 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Gray water tank Joe62984 Waste Systems, Tanks & Totes 12 01-02-2004 07:45 PM
cleaning up toilet tank release handle CindyH Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
