Can anyone tell me if the black water dump valve can be repaired from the small access panel that appears to be original approx. 4"X 6" that are located directly below the valves. I can touch the screws on the valves but I don't know if there will be any wiggle room to remove & install the new seals.
I've never had to tackle one on a vintage A/S, but I can tell you that they sure require more than a 4" X 6" space to R & R one on any newer RV. The biggest problem is getting the interior gaskets properly aligned on either side of the blade while prying the piping apart to give you a little wiggle room. See what I mean?
__________________ Lew Farber -Certified Master RV Tech (currently on Forums sabbatical) WBCCI #1456/VAC (assoc) #1456 AIR # 10325 CHARTER MEMBER: FOUR CORNERS UNIT
If the gate valve is glued to the exiting sewer pipe then it is a BIG job. That's the way my 76 is. You will have to remove the rear bumper, the big plastic sewer pipe storage compartment and cut the sewer pipe off of the valve on the front side of the metal cross member, which means you will need a big access hole under the valve. Then you will have to replace the connecting Y joint that you cut off with a new one and perhaps cut and add some spacers to get it all back together!! It's doable but not simple. Been there, done that! My advice, replace BOTH gate valves with NEW ones. Bill
My comments apply to a "REAR BATH" Sovereign. Bill
