Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-26-2009, 04:17 PM   #1
Profile:  1976 Argosy 22
chapmansboro , Tennessee
76-argosy waste valve
i have a handle stuck on black water.I tryed wd40 but wont move. any suggestion? do not know best way to replace valve. thanks for any help.
airhead 76 is offline   Reply With Quote
Old 08-26-2009, 05:43 PM   #2
Profile:  W. Van Lear , Ky
I also have a 76 28' ARGOSY and had the same problem. I had to pull the pan under th valves themselves ansd lube them. They work ok now.
Hope this helps
wingnut73 is offline   Reply With Quote
Old 08-26-2009, 05:55 PM   #3
thanks for the quick reply.do i need to remove bumper to get the pan off? thanks
Old 08-27-2009, 04:59 AM   #4
I did not have to. If you look under it you will see a panel attached with screws. the valves are under that
63 Safari waste valve rebuild airstream4 Waste Systems, Tanks & Totes 19 06-04-2008 08:31 AM
How to extend the waste valve hookup tincuplady Waste Systems, Tanks & Totes 3 05-23-2008 01:39 PM
waste valve 1963tradewin 1959-69 Tradewind 8 05-23-2008 08:27 AM
Waste valve handle Cochese Waste Systems, Tanks & Totes 1 09-30-2006 10:04 PM
Waste valve picture mtnman Waste Systems, Tanks & Totes 5 12-13-2005 11:09 AM
