Old 10-30-2015, 12:40 AM   #1
1975 Argosy 24
Snoqualmie , Washington
75 Argosy-HELP tank won't open
We are pretty new to this. Restoring to start living in full time. Suppose to move in Sunday. Just tried to open gray tank and some water came out but not much. Black tank just won't open. Not sure what to do!
Jenna0301 is offline   Reply With Quote
Old 10-30-2015, 04:10 AM   #2
mandolindave's Avatar
Not sure but
It could be that the black tank is dried up. You could try adding a few gallons of warm water and some Ridex ( an enzyme septic tank treatment ) Give it a few days to do it's magic. Then gently try to loosen the valve gate, bit by bit, back and forth
mandolindave is offline   Reply With Quote
Old 10-30-2015, 04:26 AM   #3
Wow
Are going to spend the winter in the trailer in Washington????
Find and Read the forum section on the topic. Electric heat might be the easiest. You will need a foam skirt to form a basement, heat it with a few incandescent bulbs. Heating your water( in and out ) with those heat wires.
You may find that you need a dehumidifier
Old 10-30-2015, 07:53 AM   #4
1975 Argosy 24
There is water in the toilet so the tank is full. Not sure how to add anything else....
Yes we are in Washington! We will be using electric heat!
We DID discover the need for a dehumidifier. That is on the way!
Old 10-30-2015, 08:33 AM   #5
Jenna.
Electric heat will not protect the water system.
Heat must be circulated around some of the copper tubing and holding tanks, during freezing weather. That will not happen when using electric heating for the living area.
You can however, use electric heating, but the furnace must also be used frequently when the outside temperature is below freezing. If not, piping and the holding tanks and water tank will freeze up.
The cost to correct damage caused by freezing can run into thousands of dollars. Ask anyone who has been there and done that.
Old 10-30-2015, 11:14 AM   #6
texastex
Texastex's Avatar
1984 34' Excella
GARLAND , Texas
Camping in winter location I use electrical heat tape home my water line and wrap with pipe . Insulation. Do Not leave your sewer open , Dump normally when necessary as though you were camping. I use 3 ceramic heaters one in the bath area another one in the bedroom area and a larger one for the living area. Making sure that all the are not the same circuit
Texastex is offline   Reply With Quote
Old 10-30-2015, 04:20 PM   #7
1973 31' Sovereign
Middletown , California
If you can see/reach the outside of the valve blade make sure it is clean and smooth (no buildup from gray water sitting against it) and well lubricated and then pull harder. Also try and siphon out water from above through toilet and then add enzymes and let sit. If all fails obtain Jabsco macerator pump and suck out from toilet and then unbolt valve halves and clean well. Unpleasant problem to fix! Good luck! Leland
ijustlee is offline   Reply With Quote
Old 10-30-2015, 07:16 PM   #8
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
When my black tank valve was stuck open I just loosened the two bolts that hold the valve together a little bit, just to give it a little more free play. I then squirted WD 40 on and in and around everything on the valve. I let that soak in. Then I very carefully started working the valve handle in and out. At first it barely moved at all, but gradually by tapping on it and pulling on it the valve freed itself.
terrencecolp is offline   Reply With Quote
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Blackwater valve handle won't shut or open all the way melbel Waste Systems, Tanks & Totes 11 11-03-2010 11:37 AM
My 1975 Overlander lock won't open, it just keeps turning LucyPepper Doors & Locks 2 06-22-2009 06:36 PM
'75 Overlander lock won't open..help! LucyPepper Windows, Doors, Locks & Vents 1 06-22-2009 01:12 PM
Tambour door won't open Rog0525 Cabinets, Counter Tops & Furnishings 9 11-29-2003 11:48 PM
