Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-05-2007, 02:06 PM   #1
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
75/31' mid bath dump valve
With thanks to the "75/31' valve repair" thread, here goes a slightly different effort on a mid-bath. By the way, the photo in the other thread looks like a mid-bath, too, from what I see in the repair manual, here:
http://www.airforums.com/forums/394393-post5.html
I don't see any access panel and the belly pan is tucked inside the frame in a way that will make it almost impossible to remove, so my first step will be to cut an appropriate access hole, to be covered later with a new panel.
Name:	Dump--6871 step photo.jpg
I'm lucky to have gotten the 1975 Maintenance Manual with the Sovereign. This manual covers every model and variation, which gives some hints as to where wiring, pipes, and tanks are in other 70's trailers. Woohoo, as my daughter would say.
The frame is clearly "stepped" in the photo above, but I don't see that in the drawing below. I guess I'm about to find out if the grey and black tanks are on different levels and why.
Name:	Dump--frame drawing-s.jpg
ID:	38698Click image for larger version
Name:	Dump--Frame parts list-s.jpg
The tank drawing below matches well with the photo in the link above.
Name:	Dump--tanks drawing-s.jpg
ID:	38700Click image for larger version
Name:	Dump--tank parts list-s.jpg
The scary/aggravating "news" from step "f" below is that the valves are glued in and must be cut out to repair. I can't wait to see if there is a better scheme for reinstalling them. Right now I only need to fix the gray valve.
Name:	Dump--termination valve-s.jpg
Plan of attack:
1. Cut large access hole.
2. Take a long look.
3. Come back to forums and see if anyone has some good ideas.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Old 06-05-2007, 04:09 PM   #2
Profile:  1977 29' Ambassador
Brandon , Mississippi
Zep
A big cork?
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
'Epiphany' the 29' Airstream and a honkin' long 34' named AlumaTherapy
Old 06-05-2007, 07:23 PM   #3
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
A birds eye view, If you look close you can see where I cut the 3" pipe and used a hubless conector to put it back.
The grey water is at the bottom of the pic. The two holes that were cut by the PO were a joke unless you have a trained ferret to do the job.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 06-06-2007, 08:27 AM   #4
1977 23' Safari
1975 31' Sovereign
I see the flexible hubless connector that reattaches the gray water the to sanitary wye, but what is the silvery-looking wrap that's between the termination valve and the gray tank? Did you have to cut at two places? Also, it looks like you only worked on the gray valve--is that right?
I'm trying to avoid going through the floor. Do the 3" pipes go through holes in the frame members, or under the frames? It looks like the spacing in there is very tight, so I'm concerned I'll get the belly panel open and find I have to go through the floor anyway.
By the way, I take it that you insulated the black and gray tanks yourself and maybe the silver stuff on the exit pipe from the gray tank is just insulation?
Thanks for the help,
Zep
Old 06-06-2007, 07:31 PM   #5
Silver Mist
LI Pets's Avatar
Zep
Just one cut where the hubless is. The silver wrap is just foil bubble.
I did both tanks gasket kits direct from Thetford about $20
Only the one dump pipe on the right goes thru the frame.
The pipe to the grey water just fits in the cross member hole.
I'm not suggesting you cut the floor its just at that point in my restoration it worked out. I'm showing that view so you can figure where to cut access hole(s).
You may just want to cut one large one then get the same guage metal to make a larger cover plate and use self tappers to replace.
Yes that's correct!
WBCCI
Old 06-06-2007, 08:03 PM   #6
1977 23' Safari
1975 31' Sovereign
Excellent. I take it that making that one cut allows the downstream side of the gray valve to move and the longer wye on the downstream side of the black valve has some movement through the frame, so you can then disassemble it, too?
I guess I'll get in there tomorrow or the weekend.
Zep
Old 06-06-2007, 08:17 PM   #7
Phil Gobie's Avatar
Miami , Florida
Zep; The silver is the outer wrap of a no hub coupling (3"). Being a plumber by trade it would seem this would be a routine repair for me. But i am not familiar with the A.S. access. Re:The (glued) or cemented joint that you said needs to be cut out. We often separate or remove hubs from joints by heating them with a heat gun, scoring a cut lengthwise and pealing the hub off of the pipe. There are also other repair joints that utilize a rubber sleeve and hose clamps usually called Fernco coupling which is a brand name. They are longer and more pliable and depending on the application they may each have advantages. If I get to mine I will let you know how it goes. Good luck
Phil
Phil Gobie is offline   Reply With Quote
Old 06-06-2007, 08:54 PM   #8
Silver Mist
LI Pets's Avatar
Phil that silver is just the foil wrap.
I know the type of hubless you mean that has like a chrome sleave or jacket around it, I have none of those.
Just one hubless with two SS clamps.
WBCCI
Old 07-05-2007, 10:35 AM   #9
1977 23' Safari
1975 31' Sovereign
This thread continues here, where the fix is posted:
Mid-Bath Termination Valve Fix
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 02:01 PM
Sticking Dump Valve 74SovereignInt. Waste Systems, Tanks & Totes 12 10-05-2002 07:14 PM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 0 10-02-2002 08:28 PM
Tedford dump valve 77caravaner Waste Systems, Tanks & Totes 0 09-29-2002 05:58 PM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 01:19 PM
