Old 11-28-2012, 04:12 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
'74 Tradewind Black Tank Removal?
We are looking at replacing the black tank on our "74" Tradewind. From what I can see it sits above the floor. Is it removed from above the floor or underneath? Do I need to remove the sink as well? How involved is removal of the tank? Anyone have pictures of their replacement process? Thanks!
Roadrunner
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 11-28-2012, 04:41 PM   #2
Roadrunner
TAC PA-5
WBCCI 4871
I will check the 74 service manual for you, but I cannot do that until I get back, which is Dec 12th.
Aloha
Old 11-28-2012, 04:49 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Please -- anybody else post here to help Roadrunner get a fair answer. Otherwise posts like this receive way too little attention way down the road..
There's got to be a variety of tank sources out there. What always matters is getting the inlet & outlet correct. Ideas please...
5 meter Langford Nahanni
Old 11-28-2012, 07:03 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This is from the 75 service manual.
Richard
Old 11-28-2012, 07:27 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a '74 Argosy and have removed the black water tank to do floor repairs.
I did not have to cut a hole in anything. I did have to remove the toilet, along with the vanity and the box that covers the tank. The toilet flange will need to be removed.
I'm not sure where the dump valve is on your trailer. The Argosy dump valve is in the trunk. I simply loosened the hose clamp and pulled the tank up and to the left to remove it. From inside the trailer. Of course the vent stack will need to be disconnected as well.
Old 11-29-2012, 04:00 PM   #6
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Thanks for those that replied with suggestions. TG Twinkie I checked out your blogs...nice work on your Argosy. Curious how the tiles have held up. Nice cabinet work...
Bob Leopold
Indiana, PA
TAC PA-5
WBCCI 4871
Old 11-29-2012, 05:16 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Roadrunner; Thanks for the compliment. But I'm not clear on the question about tiles.
Old 11-29-2012, 07:18 PM   #8
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
TG Twinkie I was referring to the picture on your blog of your remodeled bath. It looks like you used tiles on the floor and to cover the black tank cover. Was just curious as to how the grouting has held up to the flexing of the trailer.
Old 11-29-2012, 09:17 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Roadrunner;
It's not tile. It is vinyl flooring.
Wanted something that is easy to clean.
Old 11-30-2012, 07:25 PM   #10
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Black Tank is Out - And It Leaks
Well there was no way to avoid this...part of the bathroom is removed and the blacktank out. As you can see from the pictures, the black tank is beyond repair. Sides are cracked, the vend pipe connection cracked, and the bottom cracked too. Looks like the PO had this tank out and tried to repair it at one time. I suppose while I have things torn up I'll replace the plumbing with pex as well. One thing leads to another on these old trailers...but will feel much better once new tank and plumbing is in.
Bob Leopold
Indiana, PA
TAC PA-5
WBCCI 4871
Name:	Black Tank Out.jpg
ID:	173655   Click image for larger version
Name:	Shower Sink No Tank.jpg
ID:	173657   Click image for larger version
Name:	Black Tank .jpg
Name:	Black Tank Top.jpg
ID:	173659   Click image for larger version
Name:	No Cabinet.jpg
Black water tank removal 1975 Mus289 Waste Systems, Tanks & Totes 7 04-17-2017 08:27 AM
Time for a new Black Tank Where to start? NicheVintage Waste Systems, Tanks & Totes 2 12-26-2011 09:25 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
