Old 06-01-2016, 08:36 PM   #1
1974 25' Tradewind
Berryville , Virginia
74 trade wind need probe configuration for waste tanks
My 74 trade wind has the two tank holding system.
First on the control center it lists Aux tank and Main Tank. Which tank is black water tank and which is the gray water tank?
My black water tank has 5 probes, my manual show 3. I need to verify the correct color configuration of the 5 probes. I have
Brown on top
then Green parallel with Blue
Then purple parallel with Red
I am trying to get the control center to work and need to make sure I have the correct wiring layout on the tanks.
I can not get to the gray water tank yet but need its wiring configuration color lay out as well.
I have to have this wiring correct or the needle volume gauges will not work correctly.
Any help is appreciated. Barry
batt is offline   Reply With Quote
74 Tradewind need probe wiring configuration batt Fresh Water Systems 0 06-01-2016 08:21 PM
Probe cleaner AWCHIEF Waste Systems, Tanks & Totes 3 07-04-2015 07:22 PM
Heated holding tanks on 1976 Trade Wind? Patricia720 1970-79 Tradewind 5 01-09-2014 12:01 PM
Holding tank probe replacement gloran Waste Systems, Tanks & Totes 7 05-18-2010 07:40 AM
05/25' Classic Black Tank Sensor Probe KANEHILL Waste Systems, Tanks & Totes 1 10-06-2007 01:18 PM
