Old 01-25-2015, 08:24 PM   #1
Newberry , Florida
'73 Overlander Galvanized Box Housing Black Tank
This past hunting season, while towing my '73 27' Overlander from Cordele, Ga to Newberry, FL, the galvanized box and steel angle iron supporting the black tank gave up the ghost. Threads I've found discusses in most cases the box is too far gone to get good measurements. Although this one is rough, I was able to pull a good measurement down every line for anyone who needs a reproduction from a local sheet metal shop. Hope this helps. Anyone interested in any other pics during this repair, let me know.
ID:	231121   Click image for larger version
ID:	231123   Click image for larger version
ID:	231125   Click image for larger version
ID:	231127   Click image for larger version
ID:	231129   Click image for larger version
Overlander is offline   Reply With Quote
Old 01-25-2015, 08:26 PM   #2
Newberry , Florida
What is the opinion on replacing the black tank itself? It appears to be in good shape, no leaks, no cracks...
Old 04-08-2015, 08:49 PM   #3
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Does your '73 have black and grey tanks?
I'm doing a shell off on my '74 Overland and it has black & grey tanks.
The pans are shot and I will have to fabricate new ones. Just wondering what you did with yours.
2Rhinos is offline   Reply With Quote
Old 04-08-2015, 09:19 PM   #4
1971 27' Overlander
Jackson , Tennessee
I reused my black tank; had to rebuild the sloped foam underneath from Styrofoam and had a local heating and air shop make a galvanized pan to size.
This is all that was left of my pan. The PO had screwed on a stainless steel sheet as a replacement for the belly pan under the tank which kept the whole rusted mess from falling on the ground.
TennTex is offline   Reply With Quote
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Galvanized fresh water tank Cristobal Fresh Water Systems 1 05-30-2014 05:43 PM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 05:37 PM
Replacing Galvanized Steel Tank - '61 Bambi AirstreamGypsy Fresh Water Systems 21 05-06-2006 10:24 PM
pressurized galvanized tank vs. water pump 59er Water Heaters, Filters & Pumps 12 05-03-2005 03:58 AM
