Old 08-10-2011, 06:21 PM   #1
1973 29' Ambassador
Columbia , Missouri
'73 airstream needs sewer tank
I am looking for a sewer tank for a 1973 airstream land yacht ambassador, center bath! Any ideas where I might find one? My local repair shop guy can't find one?
Jakewith72as is offline   Reply With Quote
Old 08-10-2011, 08:33 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
See if this thread from a couple days ago helps any:
http://www.airforums.com/forums/f444...ere-80673.html
Old 08-18-2011, 08:28 PM   #3
1974 25' Tradewind
Berryville , Virginia
try this email, kim@elmonteplastics.com
they made a lot of the AS tanks.The tanks usually have the manufacturers logo on them as well as the tank # printed on them. If your is a molded white colored tank they may still have the mold.Get all the info off the tank. Kim also offered to do the weld for me. Another option is to take the old take to a poly tank manufacturer and have them poly weld it back where it is cracked. That's what I did since my tank was no longer available . Cost me $60 and worth it since I did not have any options left.
batt is offline   Reply With Quote
Old 08-18-2011, 09:52 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Have you tried inland rv. Andy might have one.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-20-2011, 07:21 AM   #5
1973 29' Ambassador
Columbia , Missouri
Thanks you purman, inland does have one and I ordered it yesterday, not cheap but timely
Old 08-28-2011, 07:04 PM   #6
1973 29' Ambassador
Troutville , Virginia
Have a 29 ft center bath - Found original black water manufacture, faxed picture with dimentions and had one made - you need to add gray water tanks I had a local plastic manufacture make one that I installed between two of the cross frame pieces - gives me approx 45 gal of gray water capacity - requires new plumbing and tank support etc - works good.Jim J.
Jim Johnson is offline   Reply With Quote
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
