Old 04-12-2015, 07:28 AM   #1
johnamjr's Avatar
1970 25' Tradewind
parkville , Maryland
70's AS black tank sensors replace?
Ok we have our black tank pulled on our 25' 1970 trade wind. How do I test the water level sensors and or how to replace with new?
johnamjr is offline   Reply With Quote
Old 04-12-2015, 11:16 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Replace whole system with a Seelevel system
Old 04-13-2015, 06:06 PM   #3
johnamjr's Avatar
1970 25' Tradewind
Thanks that looks like the way to go.
Old 07-25-2015, 06:28 AM   #4
johnamjr's Avatar
1970 25' Tradewind
I called seelevel told them what I had. They told me what I needed. Price was reasonable. Great product!
Old 07-25-2015, 12:58 PM   #5
Aerowood's Avatar
Arvada , Colorado
They have good customer service also. I called them after I received the system as my grey water tanks were 4" in depth and you could only cut down the sensors in the kit to 4 1/2". So they exchanged one sensor for one that could be cut to 4"
Old 07-25-2015, 01:33 PM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I had asked them a while back, and they told me that 4 1/2 was the shortest they could go. (I have 2 of the 16gallon vts tanks...since I bought them, they've come out with a 5" model, and I was thinking of upgrading one of my tanks, mainly so I could use the see-level. A few more gallons of grey capacity is always welcome, too, but its secondary!
So, they must have a newer model sensor?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-25-2015, 03:19 PM   #7
Aerowood's Avatar
Arvada , Colorado
I'm waiting for a flight at a airport right now so I'll get the p/n for you when I get back, but I believe you can cut the 5" down to 4" the 12" could only be cut down to 4 1/2". Maybe it was a 6"that could've cut down, I can't remember
Old 07-26-2015, 12:12 PM   #8
Aerowood's Avatar
Arvada , Colorado
Here's the smaller sensor that can be cut to 4"
https://www.garnetinstruments.com/pr.../709js-sender/
Old 07-26-2015, 01:42 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Right, I remember now. They also say that you need to leave 1/4" or so on the bottom and top of the tank wall, as the plastic gets thicker there...and the VTS tanks aren't even quite 4" (mine measure 3 7/8ths). So...that's why I was going to just go for the newer tank...maybe sell the other one on the classifieds, if anyone wants a bargain and can accept my drain/vent locations, or drill their own.
I still need the other 4"/original size vts tank for its shorter length(width?) , because my shower drain/p-trap needs to drop into the same frame bay, so I can't consume the entire space with tank.
Air:291
Wbcci: 3752
'73 Safari 23'
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
How to clean black tank sensors? ole81 Waste Systems, Tanks & Totes 4 06-04-2014 07:57 PM
black tank and toilet flange; when is it necessary to replace the tank? Globie64 Waste Systems, Tanks & Totes 7 09-07-2011 05:04 PM
Holding Tank sensors andyfuson Waste Systems, Tanks & Totes 43 01-09-2009 11:16 PM
Holding Tank Sensors seamusthegray Waste Systems, Tanks & Totes 7 11-08-2004 04:38 PM
