Old 04-24-2011, 08:09 PM   #1
1967 20' Globetrotter
1969 27' Overlander
sacramento , California
69 Overlander water tank swap
After discovering rot in the front of my trailer I pulled up the floor to discover some decay in the frame,,so at this point after pulling out the goucho & the water tank , I decided I want to put a dinette in the front,which wont allow me to use the current tank so my thought was to build the dinette seats around two water tanks hooked together which would allow leg room under the centralized table.Curious what the folks who've done this conversion, did about the storage of fresh water.I also have a 1970 overlander which has the tank hidden ,not sure where though, any ideas? Another thought would be to build aframe & support a tank in between the frame under the floor as it is already open right now.Any ideas & thoughts on this would be apreciated & also any sources for custom poly tanks .If I did have the tank below the pump in it's current location would that be too much for it to draw water uphill.Thanks in advance.Ian
colin57 is offline   Reply With Quote
Old 04-24-2011, 08:19 PM   #2
The 70's water tank is below the floor, ball park between the axles or just forward of them.
You can use a 30 gallon tank, which is what yours is now, that was used in 66-67. It fits under the front window. Then it will not interfer with the dinette. Airstream made many such coaches.
Old 04-24-2011, 08:23 PM   #3
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
Our 68 Ambassador rebuild
Our tanks are now located between the frames--we have 2 (30 or 35 gal) white connected to each other and 2 gray tanks that are connected to each other (Uwe did the work and I think he posted photos on his web site: www.area63productions then blog "Grand Reveal". We also replaced the gaucho with a dinette--we love it. paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
'69 Overlander water tank swap colin57 1965 - 1969 Overlander 1 05-30-2011 09:11 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
