Old 07-15-2013, 08:09 PM   #1
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
69' Caravel waste tank removal
Hi,
Looking for some guidance with this 69' Caravel waste tank. The number stamped on the side is a T1244 Inca. It looks like I have to replace the tank due to broken flange tabs that bolt the slide valve in place. Fortunately this little tank is an above floor and easily removed (almost)
How does the toilet flange come loose from the top of the tank? Toilet is removed, all Phillips screws are out but the flange and moulded inlet are firmly in place. Is it sealed or plastic welded in place? Once this is removed I can slide the tank out but I don't want to damage the shower pan. Thoughts or advise?
Thanks for your help
Vinnie
ID:	190999   Click image for larger version
ID:	191001   Click image for larger version
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-15-2013, 09:10 PM   #2
moderator
Airslide's Avatar
Wilton , California
Images: 50
Here's an update to my question.. how about the bottom side flange that the valve mounts to.. is it possible that it threads into the tank in some way? Is that part available separately? The tank is not fiberglass and seems to be in decent condition.
Thanks Vinnie
Old 07-15-2013, 10:27 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Some of those were actually fused into the tanks and never intended to be removed... Inca plastics is still in biz and I think you could order a replacement based on the number on the tank.
Inca Plastics
Ontario CA
909-923-3235
Home
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-15-2013, 10:30 PM   #4
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thanks Janet,
I will give them a call tomorrow and seek their advise. The tank seems to be in great condition so I was hoping for a service solution vs. replacement. I found this adapter online.. wouldn't it be nice it if had threads on it.
Vinnie
Old 07-15-2013, 11:04 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the toilet flange is like the one in my '74, it is screwed into the tank. I made a spanner wrench out of a piece of flat stock with pins that match the holes where the flange bolts are. Then just unscrewed it from the tank.
Can't help with the bottom flange. Mine has a slip fit.
TG Twinkie is online now   Reply With Quote
Old 07-15-2013, 11:12 PM   #6
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thanks TG,
Its very tight but I was able to get some movement on the toilet flange. Before I remove that which means I am removing the tank I was thinking a bit more about the lower dump valve flange. I suppose I could always try to unscrew it since they are two very different types of material .
Thanks Vinnie
Old 07-16-2013, 09:47 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I am not sure the lower flange is screwed in. You might check with the Mfr..
Old 07-16-2013, 10:28 AM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thanks Janet.. called Inca and they were very helpful. The T1244 is just their license number so I have to hunt around for the actual part number if possible. Heidi is the pro at the old tanks and will be in tomorrow. Maybe she will have more info about the lower flange when I call back.
Vin
caravel
