Old 08-29-2010, 08:56 AM   #1
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
'68 Globetrotter dump valve trouble
Need some advice. I put a Thedtford adaptor and then a store bought shut off valve on the rear black water tank so I could control the draining process. Got the unit with just a cap. Problem is there is not enough room to attach the hose in such a cramped storage box. What would work would be a 90 degree shut off valve straight off the tank since the bottom of the storage tray drops for access for dumping. Has anyone solved this problem? I have seen angle valves but not shut offs from VTS.
Randy Gates is offline   Reply With Quote
need help with dump valve? (new at this) newtothis73 Waste Systems, Tanks & Totes 3 11-07-2010 05:25 PM
Leaky Dump Valve 1969 21' Globetrotter dbaur Waste Systems, Tanks & Totes 9 07-23-2007 08:38 AM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 02:31 PM
Dump valve ALANSD Waste Systems, Tanks & Totes 4 12-04-2002 06:07 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
