Old 04-01-2006, 09:01 AM   #1
67 Globetrotter septic identification
Hi is there someone that can help me with a diagram of the septic system for this year and model trailer? When I open the lid on my rear bumper, I see one tank with a large train hole and two smaller plastic hoses coming out. I suspect that there is a tank missing.Also there is some corrosion on this tank.How easy are these to repair or replace and where can I find them.Thank you, Ray
nu2argosy is offline   Reply With Quote
Old 04-01-2006, 11:46 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Ray!
I can't help with all of your questions, but what you are describing is likely "mostly" original. Prior to 1974, wash water tanks weren't offered on Airstreams. On my Overlander, the streetside drain services the kitchen sink while the curbside drain services the tub/shower and bathroom vanity sink. Both of these smaller drains enter the between the dump valve and termination cap on the rear of th coach.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 04-01-2006, 12:35 PM   #3
Coloradobus's Avatar
Nu2argosy,
The two smaller holes you are describing in the bumper area wall are for fresh water drain tubes when your draining and winterizing the fresh water lines. They are usually controlled by small ball valves. We replaced all of our '67 Globe Trotter's copper plumbing with lighter weight plastic PEX tubing. since we had the trailer all apart. We created very high and low points so the plumbing will drain by simply tilting the trailer side to side and front to back. Add 3 gallons of RV antifreeze in the water tank tilt the trailer so the antifreeze is picked up the water pump, presto winterized.
Coloradobus is offline   Reply With Quote
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-30-2005 12:56 AM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 10:41 PM
Replacing my 64 Globetrotter Floor BobbyW Repairing/Replacing Floor &/or Frame 4 06-28-2002 12:28 PM
