Old 03-25-2009, 11:48 AM   #1
1967-Caravel's Avatar
1967 17' Caravel
East Bernard , Texas
67' Caravel Dump Valve Replacement 18706
I'm wanting to replace my dump valve on my 67' Caravel. I've noticed between the dump valve and the tank there is a mouting flange that I guess the 4 valve screws mate into. The four screws on my dump valve are very corroded and rusted badly one of the screws barely even has a head left. Does the mounting flange it screws into have metal inserts or threads it screws into or is it plastic threads. I would hate to strip one out. I might have to grind the head off to be able to get the valve out but will I be able to remove the rest of the screw. I'm sure someone out there has run into this and might have a good suggestion.
Steven
"he who dies with the most toys wins"
1967-Caravel is offline   Reply With Quote
Old 03-25-2009, 12:07 PM   #2
Overlander & Sea's Avatar
2021 27' Globetrotter
Gulfport , Mississippi
Images: 35
Steven,
Is your dump valve a Brass Thetford Valve? I know mine is on my '61 Overlander. I rebuilt my dump valve & it works fine now. But, if you want to update it, this link may help;
Restoration resources-Thetford Dump Valve
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 03-25-2009, 12:20 PM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
I bought the rebuild kit for the 68 Caravel direct from the company, nice people. If you get the kit it may help. Seems it was very reasonable priced. I think the flange on the tank was metal but I am not sure.
Over59 is offline   Reply With Quote
Old 03-25-2009, 01:01 PM   #4
1967 17' Caravel
No mine is just the plastic dump valve type......... I'm more curious about being able to get the rusty screws out without creating more problems.
Steven
Old 03-25-2009, 01:22 PM   #5
The mounting flange is all plastic. You must be careful when you tighten the screws so that you do not strip the threads. But if you do, new flanges are available.
Since you only got 42 years of service from the original valve, replacing it is far more prudent than a rebuild.
Rebuilds won't begin to last that long, assuming the rebuild ordeal went ok.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-25-2009, 01:23 PM   #6
Not sure about the '67, but on my '63, there is a brass casting that is fiberglassed into the bottom of the tank. That casting has 4 threaded holes tapped into it, to accept the 4 threaded rods that come up from the valve assembly.
Mine were rusted and broken off, but since I have the black tank out of the coach during a major renovation, I was able to take it to a local machine shop and have them remove the screws and clean up the tapped holes in the casting.
For pictures, feel free to check out my blog linked below in my pictures, this was all done about 3 or 4 posts ago, or roughly a month ago.
Good luck!
Old 03-25-2009, 04:47 PM   #7
1967 17' Caravel
So Andy if the plastic flange has threads in it for attaching the valve too..........then whats holding the plastic flange to the holding tank? Is there more screws I just dont see covered up by the valve?
Steven
Old 03-25-2009, 05:00 PM   #8
1967 17' Caravel
I opened up your blog utee by there are no pictures coming up.
Steven
Old 03-25-2009, 05:12 PM   #9
The plastic flange is made with no threads for the screws.
The threads are made in the flange, the first time the screws are inserted.
Your flange should be held into the plastic tank, with a clamp.
Releasing that clamp, would allow the flange to come off.
On the output side of the valve, there should be what is called a collector, where the gray water enters on the side of it. It may be cracked. If so, we can repair them as there is no replacement.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-25-2009, 09:41 PM   #10
1967 17' Caravel
Well maybe the rusty old screws won't be so hard to get out after all even if I have to grind some of the heads off because there's not much metal left on a couple of the screws. The last time I checked plastic don't rust so should be able to get them out with pliers or vise grips after removing valve. Thanks.
Steven
Old 03-26-2009, 08:06 AM   #11
1967 17' Caravel
I'm assuming if when I get all this off I'll have to cut the tub drain pipe maybe about 6" back then put a rubber coupler on it to reattach it.
Steven
Old 03-26-2009, 09:11 AM   #12
Correct.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-06-2009, 08:20 AM   #13
1967 17' Caravel
Well I got it off in one piece without messing anything up. Had to grind a few of the rusted head bolts off but then was able to remove the remaining with the valve out of the way with a pair of vise grips.
Steven
Old 04-11-2009, 07:30 AM   #14
1965 22' Safari
California , Kentucky
I purchased a new thetford valve for my 65 safari and cannot find a wye fitting to match the old one..I'm thinking cut off the old valve and grind out the leftover pipe left inside. Any Ideas? Also what fiberglass repair material for a small leak where the flange mounts to the tank.
The old valve had three metal devices to hold the valve to the wye. are they necessary?The new valve is all plastic and the old had a metal face.
RiverRat is offline   Reply With Quote
Old 04-11-2009, 10:08 AM   #15
1965 22' Safari
well I answered my own query. The old thetford was not glued to the wye but was a pressure fitting with an o-ring. It popped out after a little slicing with a dremmel . Go figure. now on to the gray water line that was glued.If anyone wants pictures e-mail oyoriver@fuse.net
Old 04-11-2009, 10:46 AM   #16
1965 22' Safari
I cut the old valve off with a dremmel and as I was prying it came loose. It was installed with a rubber gasket and the metal clamps held it to the wye. On to the gray water glued fitting............ go figure
Old 04-11-2009, 11:10 PM   #17
1967 17' Caravel
Not sure about what to tell you abou the leak repair but I'm sure you can refiberglass or whatever. In this thread earlier Mr. Andy was telling me that the square flange that the valve mounts to with the 4 screws was mouted with a clamp or something but I've looked mine over from the outside and you can see by looking down from inside the toilet it looks to be fiberglassed to the tank........But yes if you have the original collector they no longer make that type which is the o'ring type below the valve and Inland RV sells a aftermarket collector which is the glue on but you have to have that type of valve because they make both. Does your valve screw on or glued on to the collector? They have a tool that you can bore the old pipe out but forgot what it is called but I'm sure you can come up with something. I'm about to make another thread in this section to show what I had to do to my collector that I had to modify cause previous owner cut off the drain cap stub. Tell me if yours looks like mine.
Steven
Old 04-11-2009, 11:14 PM   #18
1967 17' Caravel
ooops........didn't see your previous threads where you answered your own questions before I replied......sorry
Sounds like your doing the same repair I'm doing. On the gray water side I just cut the pipe in half and bought a $4 2" rubber coupling at Lowe's to attach the 2 pipes back together.
Steven
caravel
Thetford Dump Valve Replacement in my 71 Lumatic Waste Systems, Tanks & Totes 14 11-26-2016 10:06 AM
Black water backup in shower or not 67' Caravel 1967-Caravel Waste Systems, Tanks & Totes 12 03-24-2009 10:27 PM
Squirrel blocker in 67' Caravel 1967-Caravel Winterizing, Storage, Carports & Covers 6 02-26-2009 06:42 AM
Need help for Dump valve replacement . kooshka Waste Systems, Tanks & Totes 6 09-08-2008 07:21 PM
67' Caravel top clearance lights (don't work) 1967-Caravel Lights - Interior & Exterior 10 01-31-2007 10:46 AM
