Old 07-24-2014, 11:21 AM   #1
1955 22' Safari
Laredo , Texas
'64 Overlander Sewer Connection
There are several old threads on this topic but no real-world solutions:
http://www.airforums.com/forums/f444/1964-overlander-dump-line-66455.html
A friend of mine recently purchased a 64 Overlander and needs to connect a sewer hose to dump the black water tank.
The fitting is similar to the one on my 64 Bambi ll and appears to be an oddball in terms of connection type and diameter. I was able to reuse the exsting aluminum elbow piece that came with my trailer and attach it to a modern sewer hose. Unfortunately this part is miising from his trailer. Anyone have one they are willing to sell or have any other suggestions?
ID:	217284   Click image for larger version
55AS is offline   Reply With Quote
Old 07-24-2014, 11:35 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I would suggest grinding off the bayonet ears and cementing a Valterra bayonet adapter in place. Valterra makes a bayonet that is designed to fit into a 3" fitting. The inside of it may be just the right size to fit over the outside of the 1964 part, possibly with a little filing.
Old 07-24-2014, 12:13 PM   #3
1955 22' Safari
Laredo , Texas
Do you have a part number for it?
Old 07-24-2014, 08:38 PM   #4
1963 19' Globetrotter
Orion , Illinois
If it is the same as the Thetford valve on a '63 , I still have two of the elbows. I fiber glassed a new Valterra valve into the tank and no longer need them.
63air is offline   Reply With Quote
Old 07-24-2014, 09:33 PM   #5
That's a standard Thetford outlet.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-04-2014, 08:22 AM   #6
1955 22' Safari
Laredo , Texas
Nope
No it is not.
Thetford/Valterrra adapter does not fit.
Old 08-04-2014, 08:46 AM   #7
No it is not.
Sorry, but Airstream used thousands of that fitting on every trailer since the early 60"s.
Thetford, is the only company, that has always used white sewer connections.
Andy Rogozinski
Inland RV Center
Corona, CA
What size Sewer hose connection? 72Blazerod Waste Systems, Tanks & Totes 6 09-20-2015 10:12 AM
68 Safari sewer hose connection niss1679 Waste Systems, Tanks & Totes 5 04-29-2006 11:26 PM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
Sewer Connection Size? Steve Heywood Waste Systems, Tanks & Totes 11 06-04-2005 12:20 PM
2005 Bambi Sewer Connection DreamStream 2005 and newer - Bambi all models 2 03-03-2005 09:53 AM
