Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 04-28-2006, 09:46 PM   #1
Profile:  acton
63 tradewind black water tank/toilet fitting
Do they still make the fitting that fastens the toilet to the black water tank??? The piece Im talking about is the one that screws into the top of the black water tank then the toilet fastens to that over the floor.
thanks in advance
Mitch
durans54 is offline   Reply With Quote
Old 04-28-2006, 11:46 PM   #2
Profile:  1960 24' Tradewind
santa barbara , California
Hello durans54,
If you are refering to the black plastic thread on fitting called the closet flange ,yes they are available at rv stores .They may have 4 slots for the screws ,some had only 2 .it will work.
Scott
scottanlily is offline   Reply With Quote
Old 04-28-2006, 11:50 PM   #3
Profile:  acton
Thanks Scott, I appreciate it.
Old 04-29-2006, 01:10 AM   #4
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
I found that modern toilets all have 4 mounting bolts, which would necessitate a 4- hole flange, usually only to be found at RV supply stores.
The 4-bolt flanges hold the toilet much more secure during travel.
Uwe
www.area63productions.com
Old 04-29-2006, 09:43 AM   #5
Darol Ingalls's Avatar
Profile:
Be sure to replace the rubber gasket between the flange and the toilet. It works best to coat the gasket with vasaline before installing to help ot seat against the flange and the toilet.
Darol Ingalls is offline   Reply With Quote
Old 04-29-2006, 02:16 PM   #6
Profile:  acton
Thanks for the advice guys!
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 09:45 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 08:07 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 05:17 PM
Black water flush davidz71 Waste Systems, Tanks & Totes 14 04-28-2002 05:15 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vBulletin Plugins by Drive Thru Online, Inc.
