Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 09-02-2003, 08:26 PM   #1
srgntpepper's Avatar
Profile:
63 Safari Dump Valve Questions
Hello Fellow airstreamers!!!
I have a 63 Safari that the PO has converted to a park model. It still has the black tank but no dump valve. I removed the toilet and when you look down into the tank you can see the coupling where the gray water dumps in but no valve, (you can see from the tank to the ground). There is a small pipe looking thing comming out of the street side of the coach in the belly skin that spins but not pulls. Could this have been the old dump lever? Any ways what is the best route to go for putting a new dump valve on? I will be re plumbing ALL the drain lines so I will only have to worry about tying into the Black tank/ Dump valve
srgntpepper is offline   Reply With Quote
Old 09-10-2003, 07:40 PM   #2
Profile:
well i was wrong there is a dump vavle and it seems to be in working order. I am gonna clean and plumbers grease it and see how it works.......
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Dump Valve Sneakinup Waste Systems, Tanks & Totes 27 05-23-2005 03:31 PM
Dump Valve Leak David Hall Waste Systems, Tanks & Totes 8 02-17-2004 06:26 PM
Repacing blackwater dump valve Rick Alston Waste Systems, Tanks & Totes 3 02-03-2004 04:20 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 02:01 PM
