Old 12-22-2015, 08:21 AM   #1
1961 24' Tradewind
Brownfield , Maine
61 Tradewind blackwater tank removal
I've removed the entire interior of my tradewind in prep for the full monty. Only thing left is the back water tank. Toilet is off any advice/suggestions on removing it, short of busting it out. Everything else has been extremely straight forward. Hate to start smashing things now. I'm trying to hustle to take advantage of this uncommon New England weather.
Freedman is offline   Reply With Quote
Old 12-22-2015, 08:47 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Assuming it is empty, should be easily removed. Does it sit above the floor or below?
BambiTex is offline   Reply With Quote
Old 12-22-2015, 09:34 AM   #3
1961 24' Tradewind
Brownfield , Maine
It's empty. It sits above the floor.
Old 12-22-2015, 11:18 AM   #4
Images: 59
Biggest challenge might be removing the plumbing below the tank so you can lift it out. On my '59 the pipe nipple screwed into the bottom flange was froze in solid.
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
blackwater/greywater tank 72 tradewind roguebrun Waste Systems, Tanks & Totes 17 06-09-2009 01:05 PM
Blackwater tank flush inlet jordandvm Waste Systems, Tanks & Totes 2 10-26-2004 05:02 AM
Bypassing Blackwater Tank westeagle Waste Systems, Tanks & Totes 3 03-19-2004 06:35 PM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
