Old 07-24-2013, 10:28 PM   #1
1956 26' Cruiser/Overlander
1961 16' Bambi
longmont , Colorado
61 bambi plumbing-no holding tank
Hello, I have a very old Bambi that does not have a holding tank.. shower drains to ground from a small pipe, toilet does same from a big pipe. Sin seems to drain around outside of big toilet drain. Ergo Ihave no tank. Does anyone know who can make a replacement grey/black water holding tank for an early California Bambi
busboy is offline   Reply With Quote
Old 07-25-2013, 08:15 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You have to ask yourself how much trouble do you want to go through, how much capacity do you want, and how much do you want to change the interior/exterior look of your trailer.
A good place to start is with the grey water tanks available from Vintage Trailer Supply. These might mount inside your frame and either stay within the frame rails, or at least not hang much below them. You could put a grey water tank below the subfloor, and a black tank above the subfloor, but this might require a lot of modifications to the bathroom.
There are many suppliers of tanks that make tanks that will hang below your bellypan dramatically. There are also options to get custom tanks made, but these will be expensive.
