Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 10-22-2009, 09:16 PM   #1
Profile:  1979 Argosy Minuet 6.7 Metre
candler , North Carolina
59 caravanner black/grey tank renovation
I love the bath layout of my new 59 caravanner. Tha black tank is above the floor in the corner. I am thinking about adding a new grey/black tank under the floor while I am in the middle of replacing the floor. My idea is under the black tank removing the old dump valve and placeing an elbow (90 degree) then a valve before it enters the new tank. The shower and sink drains would enter the new tank in another location. The dump valve would be on the new tank since it is lower than the black tank. I know this is reversed from normal, but I would like some feedback on this idea.. Thanks so much
jeffinwnc is offline   Reply With Quote
Old 10-22-2009, 09:19 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Jeff,
need pics to visualize, and make sure to understand what you're trying to do. Sounds doable, but needs elaboration..
Uwe
www.area63productions.com
Old 10-22-2009, 10:06 PM   #3
pbearsailor's Avatar
Profile:  1957 22' Caravanner
Blaine , Washington
We've got really similar trailers, Jeff, so maybe look at my thread linked below to see what I did with my gray tank. Haven't redone the black as yet, but it'll still be the above floor type in the head.
I'm planning two dump valves on mine. I'd love to do something like what I think you're describing, but I'm hesitant to get away from gravity and a straight down exit for the black tank. I want the black plumbing to be as simple as possible.
That's what I'm thinking, anyway.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-23-2009, 06:44 AM   #4
Profile:  , Minnesota
Images: 59
I think it would be ok. Keep a few things in mind:
1. Always keep plenty of water in the black tank. The outlet is small (2") and you don't want the elbow to fill up with solids.
2. Instead of an elbow at the discharge of the black tank, put in a tee. If you orient the tee with the mains vertical, you can put a second valve at the bottom and use that as a secondary dump valve. You could use this in case the side outlet & valve to the gray tank gets plugged. It gives you a backup 'straight through' exit.
3. If you mount the gray tank adjacent to the black tank, don't make it very big. Too much weight at the rear of the trailer might reduce the tongue weight.
Sealing drain pipe to black and grey tank bmklawt Waste Systems, Tanks & Totes 3 04-02-2009 09:05 AM
Combination Grey and Black Tank Idea! A-Merry-Can Waste Systems, Tanks & Totes 8 05-05-2007 09:52 AM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 08:15 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 08:59 PM
CCD Grey/Black Tank Combo LuvSub 2003 International CCD 5 05-11-2003 08:04 PM
