Old 05-12-2003, 02:17 PM   #1
Cruiser's Avatar
1952 25' Cruiser
Dummerston , Vermont
Images: 45
'52 blackwater tank
We're dropping the belly pan of our '52 Cruiser in order to inspect/ repair water damage to the floor. So far it's worse than we'd hoped, but not as bad as it could have been! As long as the bottom is open, we want to install a black water tank (It's a park model w/o holding tanks). I remember 59 Toaster commenting that some of the 50's toilets sat on top of a raised tank, visible in the bathroom. Does anyone know what size these tanks were and how they were installed? Are they still available? We're currently looking at options. The trailer now has a marine head that empties outside the frame rails on the streetside. There doesn't appear to be much room for a tank there. It seems that any tank under the toilet would have to be raised or extend well below the belly pan (or both). A tank between the rails would be neater, but wouldn't be under the toilet (I'm unsure how to route the plumbing to it), and I imagine it would need to be shallow (the frame has a 3" profile). We also wonder about the problems with an exposed tank and freezing. We've admired photos of Levon's installation. Have others tried different solutions?
Doug
Cruiser is offline   Reply With Quote
Old 09-01-2003, 08:28 PM   #2
Images: 59
Blackwater tank
This is probably too late to do you any good, but the "raised" blackwater tank is about 5" tall, and only holds about 5-6 gallons. I have mine removed right now if you still want to see it.
markdoane is online now   Reply With Quote
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Bypassing Blackwater Tank westeagle Waste Systems, Tanks & Totes 3 03-19-2004 06:35 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
