Old 01-20-2015, 06:48 AM   #1
chriscraw's Avatar
1991 35' Airstream 350
350LE Classic dump valves replacement
Hi..I need to replace both the grey and black dump valves on my newly acquired Airstream 350LE motorhome. The Owners manual does not list the part numbers for these two valves. Has anyone found out the correct Thetford valve part numbers and located a scource. Also, any hints as to how to approach the replacement job would be much appreciated. Thanks
chriscraw is offline   Reply With Quote
Old 01-20-2015, 07:08 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Chris,
Since you have to do this, my suggestion is to change over to the industry standard of Valterra. All new Airstreams come with Valterra. Parts are easier to find and less expensive. You can also in a regular connector(Valterra) at the same time.
Parts can be found at Camping World in New Braunfels or any of the RV Dealers in your area.
I would stay away from the Airstream dealer in Buda. Have not heard good things from them.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 01-21-2015, 09:20 AM   #3
chriscraw's Avatar
I absolutely agree on all counts. I'm kind of hoping to free-up the dump valve with PeterH this weekend so as to hold-off replacement at this time. Also agree with your comment re the Buda Airstream dealer who I've had dealings with! Pity particularly in Austin which loves its Airstreams and deserves a committed and Airstream community minded dealer!
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Thetford Replacement Dump Valves perryg114 Waste Systems, Tanks & Totes 7 09-16-2013 01:50 PM
1991 Airstream 350LE Classic Class A LOW MILEAGE eBay Watch Airstreams on eBay 0 06-25-2009 02:30 PM
1991 Airstream 350LE Classic Class A LOW MILEAGE eBay Watch Airstreams on eBay 0 05-20-2009 07:30 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
