Old 08-01-2011, 04:48 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
3 tank probes; 2 lights
tearing out my bathroom, I noticed that my black tank has 3 probes. The control panel only has 2 lights for indicators. "1/2", and "full".
(I think they're actually labeled "2/4", and "4/4").
So what is the 3rd wire for? I figured there'd only be 2 probes--one for each panel light.
(and I've also had the idea that I could use these wires to attach to a new black and previously non-existent grey tank, since they're already fished up through the walls to the front of the trailer, where the control panel is).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-02-2011, 07:06 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
so, nobody can explain the how the circuitry of a conventional tank probe/level gauge system works?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-02-2011, 07:22 AM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
The most likely scenario is one common probe, and two sensing probes. the common probe would be the lowest.
When the tank fluid reaches the second lowest probe, a small current would be allowed to flow between the lowest and second lowest probe due to the impurities in the water. The indicator circuitry would sense this and light the half full light. The same thing would happen when the fluid reached the highest probe and the full light would illuminate.
Ken
Tank Level Sensor - Just Learned Something AirsDream Plumbing - Systems & Fixtures 3 06-26-2011 04:15 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
