Old 12-08-2011, 11:32 AM   #1
1976 31' Sovereign
Kingston Springs , Tennessee
3.5 inch curved sewer adaptor
I am having trouble finding the 3.5 inch sewer adapter and 3.5 inch sewer cap online. Does anyone know a supplier or a part number I can use to order?
JosephVlcek is offline   Reply With Quote
Old 12-08-2011, 11:41 AM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
You sum times can find the Sewer Caps at WALMART depending on the store.I think I found the curve part you speak of at WALMART ALSO. I did find the adapters for the older sewer connections online.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 12-08-2011, 11:52 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
You probably have a Thetford connection. Vintage Trailer Supply has them:
Thetford Valves & Fittings
If you have a Valterra connection you can get the adapters anywhere, just google "Valterra termination cap".
Old 12-08-2011, 12:45 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
PM me - I have several fittings and adapters that are new/old stock not on the cardboard display pack and loose. They are not used - they are dusty from being in my garage. I have the thetford to valterra adaptors, and the thetford 45 degree adaptor you may want. I need to reduce my Airstream holdings - it's called "clean up this mess" by the wife.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-08-2011, 03:01 PM   #5
1976 31' Sovereign
Thanks everyone - I ordered a Valterra 3.5 to 3.0 inch from amazon. Part number t052285vp in case anyone needs one!
Old 12-08-2011, 03:15 PM   #6
Rivet
If the outlet ring is white, that says it was made by Thetford.
Old 12-16-2011, 08:11 AM   #7
1976 31' Sovereign
Sorry folks, I posted a part number above as a 3.5 to 3.0 universal adaptor. I was misinformed by Valterra this is a 3" standard bayonet to a 3" Thetford.
Sewer Hose & Coupler wlanford Waste Systems, Tanks & Totes 85 05-24-2016 08:20 PM
Those pesky sewer hoses! bmccomb Waste Systems, Tanks & Totes 6 08-28-2011 08:28 PM
sewer pipe/belly pan caulk crispyboy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-21-2011 08:14 AM
Screen on Sewer Vent 73 Tradewind constructor Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-20-2011 07:35 PM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 07:50 PM
