09-09-2008, 06:15 PM
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area
1960 Brass Dump Valve ~ Not What I Expected
I've had a series of dump valve issues steming from a prior-to-me reworking of the old Thetford valve to accept Valtera fittings. Last week I decided to pull off the belly and rework things as described on an early VAP episode and RJ Dial's website.
After removing copious amounts of that expanding spray foam stuff I found the awful truth. My cast brass mounting plate appears to be mounted on the INSIDE of the black tank.
Has anyone else found this problem and is there a work-around that doesn't require tearing up my lovely bath and removing my holding tank completely?
09-09-2008, 07:03 PM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Yuk!
I know all too well what you're going through. The black tank I worked on wasn't even mine. It was from a friend's '60 Traveller that he lovingly referred to as Stinky.
If yours is like mine, it unscrews from the black tank but mine was so stuck that I had to cut the brass into pieces to get it out. This I did on my workbench before installation. I hope you have better luck with yours.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
09-09-2008, 07:11 PM
2003 22' International CCD
Kiln
, Mississippi
D,
What is it that you are trying to do? Replace the valve entirely or rebuild it to stop a leak? Looks to me you can rebuild in place - although not a very enjoyable experience to be had.
Are you also trying to replace the downstream piping?
Mike
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
09-09-2008, 07:20 PM
1963 16' Bambi
Southeastern Area
Brad, there are no screws on the tank underside exterior. I probably should have used a flashlight or snake light to check the tank interior for screws. I was so disgusted I didn't think of that at the time.
Mike, I wanted to pull off the valve entirely and replace with a Valtera set up just like the link shows in my first post. That would include the downstream plumbing with a single Valtera knife valve being all that would hang from the belly pan.
I've done a "temporary" plumbing job (don't ask how or laugh when you see it) that will work through the "Summer Thang", but it's not something I want to live with.
09-09-2008, 07:33 PM
Kiln
, Mississippi
I may not be telling you something you do not already know.
From the photo - I see not bolts or studs hanging down through the brass valve body. If you can look down from inside can you see the bolt heads? I know that will be yucky bot may be the only way. Good luck.
The only redeeming quality is the reassembly should be staight forward if you do have through bolts.
I'll look on friday at the rally.
Mike
1959 24' Tradewind
Phoenix
No, you misunderstand. The brass piece is screwed into the big hole in the bottom of the tank. It's threaded. The whole thing should unscrew once there's enough clearance and its unhooked from everything.
Don't look to closely in there, you might not like what you see. :-P
FF
09-09-2008, 07:34 PM
Kiln
, Mississippi
FF
If that's the case then all you need to do is take the valve stem off and get a bigger pipe wrench attached to a big guy.
Too much torque can crack the tank I would guess.
09-09-2008, 07:44 PM
, At Large
Our '63 had a similar valve. It turned out the screws were there, but the heads were completely rusted off, and I had to cut them off, and slide the valve down and off them. If you look close, you can see where somebody has put some kind of goo on the bottom of the tank, that will probably be where the screws are.
Once you get the valve off, you can "fix" this by:
Removing the toilet
Placing a 2" Valterra blade valve on the bottome of the tank
Marking the 4 mounting locations for the valve
Drilling 4 holes into the bottom of the tank
Dropping 4 stainless machine screws with a flat washer and a neoprene washer on them through the hole where the toilet goes into the holes
Placing the Valterra valve onto the screws (a helper is a real good idea)
Threading nuts onto the machine screws (don't forget to put the gasket on top of the valve before installing it)
Tightening the nuts evenly
Reinstalling the toilet with a fresh rubber gasket
Mount the Valterra adapter onto the valve
Mount a PVC Tee fitting so the grey water can hook into the dump assembly(2" straight by 1 1/2" side)
Mount a PVC reducer from 2"-3"
Put a 3" piece of PVC onto the reducer
Drill a hole on opposite sides of the pipe for the termination cap
Put a stainless bolt (IIRC, it's something like #6 machine screws that work best)
Install the termination cap.
Piece of cake.
09-09-2008, 07:54 PM
1968 28' Ambassador
Cedaredge
Kinda of topic, but when I looked in my black tank it was cleaner looking than the black crap growing on the walls of my fresh tank.
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
09-09-2008, 08:09 PM
1963 16' Bambi
Southeastern Area
FF
OH! I did misunderstand. Something tells me mine is stuck just as tight as yours.
And that would be my luck should I try too hard.
Removing the toilet
Piece of cake.
Easy for you to say. But it looks like the beginning of a plan. BTW, I'm glad you taught Marie how to multi-post, 'cause now I know how too.
I thought that stuff on the tank bottom was "goo" also. But it seemed to be a discolored and raised area in the fiberglass. Now that I look at this pic, it does seem there could be an outline of a square cast metal plate embedded in the tank interior, probably with threads to receive the valve like Brad described.
Eeeou! Now I don't want to look in either one.
09-09-2008, 08:25 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
i think you need the glove that mike rowe used on the Dairy Cow Midwife episode!
Ricky
09-09-2008, 09:24 PM
1959 24' Tradewind
Phoenix
No, she'll want a new one. I saw that episode and definately a new one is in order.
FF
09-09-2008, 09:53 PM
1963 16' Bambi
Southeastern Area
I missed the episode, but I can imagine
Y'all are too funny.
I made need some of these before it's over.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
dump valve (once again)
eubank |
Waste Systems, Tanks & Totes |
13 |
09-08-2007 10:56 AM |
Dump Valve
Sneakinup |
27 |
05-23-2005 02:31 PM |
Dump valve
ALANSD |
4 |
12-04-2002 06:07 PM |
Sticking Dump Valve
74SovereignInt. |
12 |
10-05-2002 06:14 PM |
Dump valve
gwsullivan |
11 |
05-30-2002 08:38 AM |
