Old 12-19-2007, 06:18 PM   #29
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Wash water can get pretty stinky.... good thing to have. What did you use on your ambassador?
-Tim
theVAP - Airstream Podcast
Old 12-19-2007, 06:58 PM   #30
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It also keeps nasty gas from backing into the trailer if you are hooked to a sewer line.
Richard
Old 12-19-2007, 07:04 PM   #31
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Thanks Doug
All, unbeknownst to you all, I secretly emailed my main parts supplier up in Canada - Shacksman. I knew he would have one if anyone would.. Thanks Shacksman. I'll email ya my address, unless you're coming through to Florida for the winter. In case you all don't know it, I owe many of my lights to Doug from one of his 58 California model....
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 12-19-2007, 07:06 PM   #32
Baltimore , Maryland
Doug, how could you... we are from the same unit. I can't believe you are helping him out.... I need all the help slowing him down
Old 12-19-2007, 07:20 PM   #33
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
I would suggest you get a PVC waste and over flow (solvent weld/cement type). use the threaded shoe or elbow and chrome drain. Exiting the drain create a rise with two street 1 1/2" 1/8 bends (sanitary 45s). you may have to roll the fittings to get the correct rise. you want to create enough rise only to make a water seal (trap).
Phil
Phil Gobie is offline   Reply With Quote
Old 12-19-2007, 08:53 PM   #34
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
You don't need any help slowing Rob down, He's quite good at doing that on his own .Just let him know where there's an old trailer sitting and watch what happens.
Everyone's in the same Unit, Colin, Rob you and me.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 12-19-2007, 08:56 PM   #35
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Still working on the Ambassador. I'll use a plastic trap somehow.
I have mine inside now and should have it done by spring. Good thing I have 2 others to use.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 12-19-2007, 10:12 PM   #36
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Hey, what about me!?!
Didn't we start our trailers about the same time? Your slacking!!
-Tim
Old 12-20-2007, 02:46 AM   #37
Tim,
I think he was talking about unit members that do things with their unit.... Jeeze, I had to offer up free Southwest vouchers just to get you to come to your units premiere event.... we haven't even figured out whose trailer we can get for you to use while you are here.
Rob,
I found a very cool trolley topped trailer at a construction yard near my plywood supplier. It is all aluminum.... Next time you are passing through we should go check it out. It is not an Airstream, but still a great looking trailer... wanta go look?
Doug,
Did I do that right?
Old 12-20-2007, 07:39 AM   #38
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Rob,
Doug,
That should do it real good. Can I come too!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 12-20-2007, 09:12 AM   #39
pauly g's Avatar
1960 22' Safari
Oceanside , California
I just used ABS fittings and cut a small hole through the belly. It was tricky to seal, but I don't think anybody will notice the hole.
pauly g is offline   Reply With Quote
Old 12-20-2007, 11:04 AM   #40
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Tim,
I'm just a struggling podcaster trying to make my way through life....
-Tim
Old 12-20-2007, 12:30 PM   #41
robandzoe's Avatar
Plymouth , New York
Trust me - Colin would notice!
Oh, I know it would be the first thing Colin would comment on "Nice hole in your belly pan" - for sure. To me, and many, belly pans are like underwear - I need nice clean ones. The least number of holes is what I'm after.
Plymouth, NY 13832
Courtesy parking
Old 12-20-2007, 12:41 PM   #42
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Yea because if god forbid you are ever in a wreak, you would not want holes in your belly pan.....
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
where to find replacement doorknobs? 1958? zydecogroove Doors & Locks 0 11-22-2007 05:39 AM
chip in cast iron sink Dwight Cabinets, Counter Tops & Furnishings 0 06-28-2004 12:10 PM
Right cast iron manifold free Astrodokk Airstream Motorhome Forums 1 10-19-2003 09:04 PM
P Trap Cup Chitown AirStreamers Plumbing - Systems & Fixtures 2 07-29-2003 02:34 PM
Stove top Black Cast Iron to go above eye tmeagle1 Stoves, Ovens & Microwaves 1 02-27-2003 10:49 PM
