Old 05-29-2005, 11:20 AM   #1
Thumbs up 16' ccd Bambi drainage system question.
I own a 16 foot bambi. I dry camp mostly. This model has only one holding tank for grey water and black water. I want to know if it is possible to drain the gray water seperately to the ground. Thus using the holding tank for black water only.
gbrentsmith is offline   Reply With Quote
Old 05-29-2005, 11:29 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It would require some replumbing of the grey side of the tank, but, yes, it could be done.
You would have to cap off the inlet of the grey water line into the black tank, and put a drain on the grey side onto the ground. Just be aware, that many campgrounds do not allow grey water to be directly dumped on the ground.
A second solution would be more complicated, involving a slide valve from the grey water line to the black tank, and another slide valve with cap to go directly to the ground. This would most likely be the preferred method, although more labor-and parts-intensive. You could then camp at the "no grey water dumping" campgrounds, as well as go out in the boonies and dump away when you wanted.
Old 05-29-2005, 11:40 AM   #3
Terry, Thanks for the quick response. Another question. Is there a any information out there showing the schematics of the pluming configuration of the bambi ccd 16'?
Old 05-29-2005, 11:46 AM   #4
Well Preserved
1993 21' Sovereign
Schematic should (theoretically) be in the service manual. I can tell you that there is most likely two grey inlet lines going into the combination tank, but it is just PVC, and easy to work with. You should also add a vent to the grey side, if you don't already have one, just to keep from sucking all the water out of your P traps when draining. Again, it is only PVC, easy to work with.
Old 05-30-2005, 10:57 AM   #5
What's the easiest way to raise a bambi high enough to work underneath.
Old 05-30-2005, 03:31 PM   #6
Well Preserved
1993 21' Sovereign
I have a pair of 7000 pound capacity automotive-style ramps that I back the trailer onto when I need access. This gives you another 6-8" of room to work. It is, of course, vital to have a spotter watch you, so you don't go too far when backing up the ramps. also, chock the wheels of the tow vehicle while the trailer is in the air, and you are under it.
Old 05-30-2005, 04:33 PM   #7
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
An inexpensive alternative would be to use a porta-potty or available facilities while "Boondocking" for the Black. Then everything going into the tank will be Gray. You could dump the Gray on the ground, where permitted and dump the Black from the Porta-Potty in a proper manner.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 08-19-2005, 04:42 PM   #8
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Hi, I have a 63 Bambi that was made in CA. It has a holding tank for black water. The grey water is a separate system that enters the system just below the black water shut off valve. So what happens is the black water is held in the tank until the valve is opened. The gray water just runs through and out to the ground. If your Bambi is plumbed different I would like details. I could send photos of my system if you like. I plan to use one of those extra tanks that sit on the ground to collect the grey water when I am in a camp that does not allow grey water on the ground.
NorCal Bambi
NorCal Bambi is offline   Reply With Quote
Old 08-23-2005, 08:21 PM   #9
Been having to much fun camping with the pod to explore the seperation of grey water from black. However, this winter will offer the time needed to experiment with this problem. I would like to see how your Bambi's drainage system is assembled. If you have pictures I would be interested in viewing them.
Later
gbrentsmith
Old 09-02-2005, 07:38 AM   #10
1963 16' Bambi
Yreka , California
Images: 21
Howdy gbrentsmith, Here are some pictures of my drainage system on my 63 Bambi. The assemblage under the floor is currently removed. If you wish I could also take a picture of the unit and send it also. The toilet was replace in 1970 I believe by the literature We recieved with the trailer.
Name:	drain & water supply630_Layer 1.jpg
ID:	14400   Click image for larger version
Name:	Toilet valve & shower drain630_Layer 1.jpg
Name:	Vent out roof sink630_Layer 1.jpg
Old 09-02-2005, 07:40 AM   #11
1963 16' Bambi
Yreka , California
Images: 21
Bambi drain system
More pictures
ID:	14404   Click image for larger version
Name:	vent out roof toilet630_Layer 1.jpg
Name:	Vent sink and hookup630_Layer 1.jpg
Old 10-17-2005, 05:47 PM   #12
2004 16' International CCD
1997 25' Safari
hamilton , Montana
bambi 16 ft,ccd, grey/black separation
hi all, i too own the grey/blackwater tank trailer and have seriously thought of buying something else. if you do the separation, could you please give me step by step instruction. am a woman and will pass info onto the installer, thanks, dieterdog
dieterdog is offline   Reply With Quote
Old 10-17-2005, 09:08 PM   #13
1963 16' Bambi
Yreka , California
Images: 21
black/gray water
Dieterdog, I have a black water tank. The gray water is piped in just under the black water tank but does not mix in with the black water. The unit was designed to just allow the grey water to run out onto the ground. This is not allowed in many states. So what I am going to do is hook up a outside portable disposal tank to the hookup under the trailer. When it gets full wheel it to a disposal site and dump it. If you would like I could send you some pictures in the next day or so.
NorCal Bambi
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 03:35 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
