Old 03-13-2009, 10:39 PM   #1
El Paso , Texas
16' Bambi Info ?
I am considering a 16' Bambi can anyone tell me the cons or problems of having only one waste water tank?
vargalu is offline   Reply With Quote
Old 03-13-2009, 11:02 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Hey vargalu...welcome to the forums, and to all things Airstream! The obvious thing about having a combined grey and black water tank is reduced holding capacity...but whether that is an issue depends on how you plan to use the Bambi. If you use it for long weekends and short trips or if you ususally have hookups or are able to dump your holding tanks frequently, then it's not as much of an issue. If, on the other hand, you use your AS such that you need high capacity holding tank capabilities, it is an issue. Think about how you want to use your Bambi and if you think you can be conservative enough to make it work, etc... That having been said, those we know who have 16' Bambis love them....
TB & Greg and Abbey Schnauzer
#3954
Old 03-14-2009, 08:04 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
The biggest problem I see is with separate black & grey tanks, typically your grey tank gets full faster than your black tank. We can go 3+ days without filling our 10 gallon black tank, but a couple of showers will fill a grey tank very easily.
In some places, it's okay to empty your grey tank or run grey water on the ground or into a culvert, etc. It's never okay to do that with a black tank...or "dark grey" of a combined tank. You must find a suitable dump station for every dump with a combined tank ~
Then there is the pure volume of the "dark grey" matter - instead of 10 or 15 gallons, you have 30+ to deal with. Which is more than likely more than one trip with a blue boy for most, if that is how you are dumping...more likely to be a messy job having to stop the flow midway.
Shari
Old 03-14-2009, 08:10 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Um, what year is the 16' Bambi you are considering? If it's a 1960's model, it will only have a black tank. If it's a nearly new one, it will likely have a combined waste water tank, usually 45 gallons.
If it is the 1960's model Bambi, you will need an auxiliary tank, commonly called a "blue boy", to hold the grey water. When full, you can trundle over to the dump station with the tank.
If it's the newer version Bambi, you will find the combined tank will fill faster than you think it would, because dirty dishwater and shower water go into the tank, and you would have to move the trailer to dump it. He-Man may be able to lift and dump a 50 gallon blue-boy, but I like my internal organs to remain where originally placed.
Old 03-14-2009, 08:13 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It think Shari nailed it squarely on the head. If you are comfortable with that as some are, then by all means a combo tank is for you.
Old 03-14-2009, 09:16 AM   #6
Head Animal Wrangler
BamCamper's Avatar
2010 19' International
Los Osos , California
Never had a problem with mine in almost four years of frequent use.
I can boondock for a week if I'm careful...short showers, occasional campground showers, paper plates so less dishwashing etc.
I don't use a Blue Boy.
Again it depends on how you use it and how many people are traveling together.
Rally on,
Bam
and no, those photos are not me.
BamCamper is offline   Reply With Quote
Old 03-14-2009, 12:31 PM   #7
pod people's Avatar
2004 16' International CCD
Santa Fe , New Mexico
I agree with BamCamper.
We have used ours frequently for over 4 years with no problems. With 2 people, we can last 3 to 4 days if we are careful (short showers and minimal dishwashing).
We did buy one of the wheeled tanks (15 gal) for use on the rare occasions we plan to be in a campground for about a week. We just fill it and tow it over to the dump station. Not pleasant - but easier than moving the trailer.
The great advantages of the 16' are tow weight and the ability to get into tight places.
We love it.
The People from the Pod
pod people is offline   Reply With Quote
Old 03-14-2009, 01:03 PM   #8
bkmoore's Avatar
2006 16' Safari
Rohnert Park , California
I agree too. One tank is not a problem and is easy to manage. It's scaled right for a 16 footer...
bkmoore is offline   Reply With Quote
Old 04-09-2009, 07:28 PM   #9
ITsIT's Avatar
2008 16' Bambi
New York , New York
I love my DWR Bambi, except for one thing, the black and grey water is mixed and the holding tank is 2 gallons less then the fresh water. I am planning to go to the Region 2 rally in Niagara Falls, it will be several days and I am taking my parents who are in their 80's & I like to shower every morning, so the 21 gallon tank will fill fast. I am trying to figure out the best way to deal with this. Do I get a Portable Waste Tank or do I tow my rig out to the dump station. And if using a Portable Waste Tank, how do I know when to stop filling.
ITsIT is offline   Reply With Quote
Old 04-10-2009, 01:06 AM   #10
bkmoore's Avatar
2006 16' Safari
Congratulations on your DWR! Nice trailer.
Using the potable totes can be a real hassle and they take up a lot of room when traveling, especially with at 16' Bambi. How about using the campground facilities? Just use the trailer's bathroom at night. You should have more then enough capacity on board to make it through the rally.
bkm
Old 04-12-2009, 10:04 PM   #11
ITsIT's Avatar
2008 16' Bambi
New York , New York
Thank you for your suggestions.
I love my trailer, it is my first, and backing up is still a mystery, but I am working it all out.
Old 04-12-2009, 10:58 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
ITsIT...don't worry, backing it up is a learned skill and you will get there...just take it slowly and carefully... I know! The first time we brought our Bambi home we entertained the neighborhood for a good 45 minutes just getting it into the driveway! Now we can back it into not only the driveway, but it's covered port with only 2' on eiher side in less than 5 minutes... Single axle trailers have a very short pivot point and once you've reached that pivot point, no matter which direction you turn the steering wheel on your TV the trailer will continue in the same direction... If that happens, just pull forward, get in front of the trialer and then you'll be able to control the direction the trailer is moving again. This works: put your hand at the bottom of your steering wheel...to move the rear of the trialer to the right, move your hand on the wheel to the right. To move the rear of the trailer left, move your hand on the bottom of the steering wheel to the left.
#3954
Old 04-14-2009, 03:17 PM   #13
ITsIT's Avatar
2008 16' Bambi
New York , New York
Thank you for all of the advice, practice practice practice will not get me to Carnegie Hall but hopefully it will get me backed into a parking place.
I have had 13 outing in my trailer since I got it and I hope by 26 Ricky (Long Long Trailer) and I will not still have the same backing trouble.
Thanks again
Old 06-07-2009, 06:45 PM   #14
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
We have a 62 Bambi (Ohio)... is there anyway a gray water tank could be added ?
62bam is offline   Reply With Quote
16' Bambi 2001 ??-- Need inspection info tinbender 1997 - 2004 Bambi 0 01-11-2008 06:44 AM
Awning for my 16' Bambi? Deadhead58 2005 and newer - Bambi all models 10 10-09-2007 09:20 PM
2005 Bambi 16' ericinrb 2005 and newer - Bambi all models 25 10-25-2006 06:54 PM
16' Ccd & 16' Bambi Ron Edwords Waste Systems, Tanks & Totes 2 03-26-2006 11:30 PM
Bambi or 16' CCD Shep Our Community 27 07-18-2003 08:51 PM
