Old 04-22-2015, 05:21 PM   #1
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
'15 Classic with Autodrain
Today I installed the Barker Autodrain system in my new Classic. Well, TWO systems actually. One for the black tank and one for the gray. I did this install on my '12 28' Intl CCD and really liked the convenience of NOT having to go outside and pull the valves. This is especially nice when I'm in a park with a sewer hookup. The Classic posed a challenge, as it has a different dump system without the visible blade valves. I had to fabricate mounts for each valve and rivet them in place, then bolt the Autodrain mechanism in place. Since I've gone to this "ONE PANEL FOR EVERY CONTROL" thing, I ran wires inside the trailer so I could put the two switches on the bottom of the control panel. They flash red when the valves are open. (Oh, I have saved the standard pull toggles so if all else fails I can pull the lever(s) manually.
ID:	236842   Click image for larger version
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Classic or Classic Limited? Bluto 2006 - 2010 Classic (all lengths) 8 03-23-2009 09:10 PM
- Classic FB 27' or Classic 30' Sky Community Polls 2 05-11-2007 02:34 PM
Classic Weight Example - 2004 Classic gklott 2001 - 2005 Classic 6 11-05-2005 12:02 PM
Classic 25A / Classic 25B DreamStream 2001 - 2005 Classic 8 04-27-2004 05:19 PM
Classic models - 2002 Classic baldeagle 2001 - 2005 Classic 48 04-16-2004 10:31 PM
