Old 11-15-2015, 09:43 PM   #1
Winterizing
Anybody know anything about winterizing a '99 Safari 23? We can't find the hot water heater bypass valves that are the next step in the winterizing process. Finally found the water pump under the kitchen sink behind a panel. Doesn't seem to be much to be found about this process on this trailer. We are Airstream newbies.
Thanks!
Libbitt is offline   Reply With Quote
Old 11-15-2015, 10:00 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you sure the coach has a bypass system?
Locate the water heater.
Follow the hot and cold water lines connected to the back of the unit. Cold on the bottom, hot on top. If you have the old system with three valves. There will be one valve in the cold water line; one valve in the hot water line; and one valve in a line connecting the cold and hot water lines together. The latter is the bypass line and valve.
To bypass the water heater you would close the cold and hot water line valves and open the bypass valve. Don't forget to drain the water heater.
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
