Old 05-02-2007, 08:36 PM   #1
Arroyo Grande , California
Why no accumulator?
Our new 20' Safari did not come equipped with an accumulator. There was plenty of room to add a ShurFlo accumulator right next to the ShurFlor water pump and the installation was quick and easy (just had to lengthen one piece of PEX tubing). Pump and water system works much better now. Any reason Airstream doesn't put them in at the outset? Roger S
Roger S is offline   Reply With Quote
Old 05-02-2007, 09:09 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Cost
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-02-2007, 09:40 PM   #3
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
What is an accumulator and why do I want one?
KL
4CU Charter Member
silverback is offline   Reply With Quote
Old 05-02-2007, 10:19 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
$40 they do not have to spend. I put one in my classic. It took the hammer out of the systems and quieted it down significantly.
Michelle TAC MT-0
Sarah, Snowball
Old 05-02-2007, 10:24 PM   #5
Airstreamer2's Avatar
1995 34' Limited
Glendale , California
Michelle,
How many pounds of pressure? Before I knew what an accumulator was, I pressed on the "valve stem" (only for a second!) so I don't know what the pressure should be. Help!
Airstreamer2 is offline   Reply With Quote
Old 05-02-2007, 11:22 PM   #6
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
Hey Roger S,
I'd like to put one on my 20' Safari, too! Happen to have a picture of your work?
I also found that putting foam pipe insulation around all the loops of PEX under the twin sinks made a huge difference in pump noise. But I definitely want to put in an accumulator. I feared it might interfere with the below-oven drawer...?
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 05-03-2007, 06:13 AM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Try one of the new 'Extreme Series' variable speed water pumps and you won't neeed an accumulator at all. They are super quiet and give you domestic quality water pressure.
Not cheap at all, but they really do the job!
Old 05-03-2007, 06:19 AM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
KL
I'm not sure, but since no one is anwsering ..... I believe it it a holding tank that is maintained under pressure.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-03-2007, 06:27 AM   #9
lewster's Avatar
An accumulator is a small water tank, usually 1-2 gallons, that acts as a buffer between the demand (faucet) and the supply (water pump) in a water system. It relieves the water pump from constant on/off action when a faucet is opened for ocassional use, as it is pressurized.
It will generally stop water hammering in a system.
Hope this answers your question.
Old 05-03-2007, 09:16 AM   #10
Keymar , Maryland
I really can't tell you. I set the pressure and tried to check it. Then it was too low. It is somwhere around 50-60 PSI.
Michelle TAC MT-0
Sarah, Snowball
Old 05-03-2007, 10:40 AM   #11
Excella CM's Avatar
Venice , California
The accumulator is a small sealed tank that is divided by a flexible rubber partition. One side of the partition has the sytem water going through it and the other side has air under pressure at 10psi. When the pump starts, the pressurized water compresses the air in the accumulator. When the pump stops the water is maintained under pressure by the air trapped in the dry side of the accumulator. This allows some water to be used without causing the pump to start every time and absorbs the hammering of the pump whiile it is pumping. To bias the accumulator, shut off the pump and open a faucet, then put 10 psi in the accumulator via the valve.
Old 05-03-2007, 12:36 PM   #12
Excella CM's Avatar
Venice , California
followup
Here is a shure flow intsruction sheet and URL:
Pressure System Accessories > Water Pressure Systems > Jabsco - ITT
Old 05-05-2007, 11:56 PM   #13
just jd.
5cats's Avatar
2007 20' Safari SE
Thanks to Excella CM's link, I read up on, then found the Jabsco Model 30573-0000 accumulator tank (1 liter) at West Marine in town today. I chose this unit over the Shure-flo 0.65 liter model available at CW because it's nearly twice the capacity with the same diameter -- and I could get it immediately
I installed it this afternoon with no trouble. This accumulator came with both threaded and barbed 1/2" QEST fittings, compatible with the existing water pump. I connected the pump to the accumulator with a short (8-10") length of flexible 1/2" i.d. 200 PSI cold water hose and plugged the existing flex hose -- QEST fitting and all -- into the tank's exit port. I figured it's a good idea to maintain a flexible exit from the pump...
I used neoprene rubber washers to sandwich the tank's mounting flange as well, but I don't think that was absolutely necessary.
All is wonderfully quiet now
Some additional observations:
  1. The factory-installed pump's mounting screws were overly tightened, severely diminishing the effectiveness of the rubber mounting dampers. The installation manual clearly indicates these should be tightened to just-touching the rubber dampers to avoid compressing them.
  2. I wrapped virtually all of the many loops of PEX plumbing under the sinks, as the stiff material vibrated against the walls, sink, and other plumbing quite loudly (before adding the accumulator).
  3. This accumulator provides a lot more running water than I expected, before the pump kicks in again. I'm real impressed.
Karma to you Excella CM, for the link.
Cheers,
-jd.
Old 05-08-2007, 02:05 PM   #14
just jd.
5cats's Avatar
2007 20' Safari SE
pics
Here are some post-install pics (click for larger):
Pump/accumulator under the oven
Side view of accumulator tank
Accumulator schrader valve is easy to access
Cheers,
-jd.
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Accumulator Tank silversled Waste Systems, Tanks & Totes 16 02-01-2007 08:32 PM
ShurFlo Accumulator?!? SilverToy Water Heaters, Filters & Pumps 6 04-19-2005 10:07 PM
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
