Old 05-19-2007, 03:23 PM   #15
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Here is the spec. sheet for a Jabsco accumulator with pressures, etc..
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-20-2007, 04:53 PM   #16
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
5cats.
What size piping did you need in connecting your accumulator.
Looks nice!
henw is offline   Reply With Quote
Old 05-20-2007, 05:50 PM   #17
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
The existing factory installed flex hose is "Accuflex 1/2" cold water IAPMO 150 psi".
I couldn't find that exact hose at Home Depot, but I did find similar 1/2" i.d. (inner diameter) flexible reinforced water hose rated at 200 psi. It didn't have a brand name or markings at all on the hose itself.
I used the QEST * 1/2" Barb fittings supplied with the kit, plus a couple of SS hose clamps.
The tank itself is mounted w/only two screws. It's difficult to see in my pictures, but I used two #10 x 1" screws, sandwiching the tank flange above and below with 1/4" #6 neoprene rubber washers, topped with a SS washer at each screw head. These are lightly snugged down, in the hopes of preventing noise transmission through the tank flange to the floor.
I think someone also mentioned to check the pump screws, too. Mine were waaaay over-tightened, completely deforming and defeating the rubber bumpers that the pump is mounted to. These should be just tight enough to hold the pump in place, w/o squishing them down.
Hope that helps! Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 05-21-2007, 06:55 AM   #18
Cracker's Avatar
Pittsfield , Maine
Wow! I sure would like to have the access to my water pump that you do. In the 30' Excella it's squeezed into the compartment underneath the closet floor along with the heater ductwork to the rear bedroom.
Cracker
Cracker is offline   Reply With Quote
Old 08-07-2007, 05:17 PM   #19
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Jabsco accumulator lasted 2 months
I installed the Jabsco accumulator about 2 months ago and really liked the decrease in pump noise. But, on our recent 3 week trip it seemed like it was not working properly. I checked the air pressure in it and water came out the valve. Upon opening it up I found the inner bladder had torn.
The manufacturer was quick to replace it but it still meant we went 3 weeks without it. We could have used the power being sent to the pump since we were boondocking most of the time and nearly ran out of electricity.
I hope the replacement lasts longer.
SilverCottage is offline   Reply With Quote
Old 08-07-2007, 06:22 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Hey all,
The accumulators work well, but they do have problems like the bladders rupturing.
As an alternative, check out the new generation of quiet, variable speed water pumps from ShurFlo. They give you residential-like pressure and no buzzing or hammering. I've been putting a lot of these in the MoHo's I service, and have one waiting for me to install in my CCD.
Old 08-07-2007, 07:33 PM   #21
Images: 59
I went a little overboard. . .
I put an accumulator and a VSD pump in my Tradewind. I even mounted the pump on special vibration isolation bushings.
The results were interesting. The accumulator will store 1/2 gal of water under pressure. When you open a tap, the water comes out very nicely, then you start to hear a gentle moan in the background as the pump spools up to speed.
It sounds like this:
. . . . bl . . . blip . . . . blip blip. . . . .blipitty blipitty blipitty blipitty blipittyblipittyblipittyblipittyblipittyblipittybl ip . . . blip blip . . .blip. . . . bl . . . .
It's very soothing.
I was gonna post some pictures, but I am evidently WAY OVER my picture limit.
Old 08-07-2007, 07:43 PM   #22
Excella CM's Avatar
Venice , California
Maybe you should just post an MP-3
Old 08-07-2007, 07:46 PM   #23
Images: 59
Is that like, some kind of spreadsheet?
Old 08-07-2007, 07:59 PM   #24
LONDON , ON
Originally Posted by lewster
Hey all,
Hey Lew, What do you suggest for the ShurFlo pump size and model for a 2007 Safari 27?
Thanks for all the excellent advice.
Old 08-07-2007, 10:29 PM   #25
lewster's Avatar
wj,
IIRC, they have a 4.2 gpm and a 5.7 gpm in their quiet series. I'll get the #'s, specifications and MSRP for you tomorrow.
Old 08-08-2007, 11:45 PM   #26
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Look No Tank...
i purchased yesterday a new:
ShurFlo Extreme Series Smart Sensor 4.0 to replace my prefectly good, loud, hammering water pump from the factory.
  • Flow of 4.0 GPM [15.14 Lpm]
  • Variable Speed Pump Controlled by Smart Sensor (trade mark sensor)
  • High Pressure @ 50 PSI No Pressure Switch Needed
  • Silent operation at any Flow/Pressure Condition
  • No Rapid Cycling
  • Seamless Heat Electro-Coated Motor Shell
  • 4 Chamber Design
  • Large Inlet and outlet Valve Passages
  • Automatic Voltage Protection
  • Current Limiting at 10 Amps Max.
purchased at RV Toy Outlet: price $160.99 tax $11.67 shipping $8.96 your price may vary as i'm lazy and didn't shop the part for price...
so i got that workin for me and you don't need a seperate accumulator tank.
kevin
Kevbo10 is offline   Reply With Quote
Old 08-09-2007, 05:19 AM   #27
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Nevermind, I'll googled it.
Try one of the new 'Extreme Series' variable speed water pumps
Do you have a link?
Old 08-09-2007, 08:11 AM   #28
lewster's Avatar
  • No Rapid Cycling
  • 4 Chamber Design
kevin
Thanks Kev,
That's the pump that I was going to get the specs on for the thread. Mine is sitting in my fresh water bay, but is not connected yet. I've been replacing a lot of water pumps lately on big MoHos and these seem to be the favorite.
BTW, I could-a saved you some $$$$$ on that pump.
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Accumulator Tank silversled Waste Systems, Tanks & Totes 16 02-01-2007 08:32 PM
ShurFlo Accumulator?!? SilverToy Water Heaters, Filters & Pumps 6 04-19-2005 10:07 PM
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
