06-05-2012, 11:30 PM
2010 27' FB Flying Cloud
Fraser Valley
, British Columbia
Why is My Water Coming Out Like Soda Pop?
Have just hooked the city water up after dewinterization. The tap water is coming out like it is carbonated - lots of bubbles with a good head on it.
I am assuming there is still air in the system and have been running the tap a lot, but it is still foamy.
Anyone else having/had this problem? Did the water eventually go flat again?
06-05-2012, 11:35 PM
1974 Argosy 20
Kooskia
, Idaho
I have seen that issue when all the pink antifreeze is not yet cleared out of the system. Try letting it run a good bit, especially on the hot water side, where the water takes time to flush out.
06-06-2012, 12:03 AM
Fraser Valley
, British Columbia
idroba, I think you are bang on with that. I tasted the water - has a definite soapy/slick taste and feel.
I haven't turned the hot water on yet. Will do. Thanks so much!
06-06-2012, 12:20 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
I have experienced the same after dewinterization. Sometimes it takes quite a lot of flushing to get all the anti-freeze out. One year I used the wintergreen flavored anti-freeze, and never thought I'd get it all out of the pipes.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
06-06-2012, 05:28 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
This is why you want to winterize with EverClear....
I agree it takes a loooong time to completely clear the lines of the antifreeze. I typically hook my trailer up to city water, fill the system up, open up the gray tank and the drain line and let er run until it is clear. We also sanitize annually using a dilute bleach solution.
Aaron
WBCCI #XXXX AIR #2495
06-06-2012, 05:45 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Aaron
Beat me to it… I was going to recommend vodka. Vodka freezes at 30-below, Everclear freezes at 110-below (Farenheit), so you only need Everclear in the great white north. Best of all, you don't even have to drain the alcohol to un-winterize (springize?), just dilute with water until you reach your desired level of inebriation. No need to add bleach for disinfecting, either; any microorganisms that can survive in the alochol deserve to live!
06-06-2012, 07:56 AM
Broadway
, North Carolina
We had this happen for the first time this year and figured out it was because this is the first time I had an RV shop winterize the Airstream. When I winterize it, I completely drain the freshwater tank, leave it dry, and fill the lines and water pump with antifreeze. In the Spring,I put 20 gallons of water or so into the empty freshwater tank and takes only a few seconds to flush the pump and the foamy lines out.
The shop apparently put pink antifreeze in the freshwater tank, and not knowing, I did not drain it before filling when de-winterizing. So, while at the RV park on city water the lines ran clear, then while on the road, the water pump pulled water/antifreeze mix back into the lines and the foaming would start again.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
06-06-2012, 10:07 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Dewinterizing is also a good time to make sure there is any "crud" accumulated in your faucet screens - while not necessarily the cause of the foaming, it can restrict the water flow & be a contributor. But the main thing is to get all the pink stuff outathere.
Shari
06-06-2012, 10:16 AM
1970 27' Overlander
Espanola
, Full Timer
Be sure to wash the antifreeze away also when it is out on the ground possibly, as animals will drink it and it will knock them out cold.
06-06-2012, 10:40 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
After all the anti-freeze appears to be out of the system, Check your hot water heater bypass, drain plug, and valve to see if air is being introduced into the water system. That is what it was for me. Spiggot looked like it was hooked into a pop dispenser.
06-06-2012, 12:10 PM
Mantua
, Ohio
I do not think this kind of antifreeze is dangerous to people. Jim
06-06-2012, 01:54 PM
Mercer Island
Do you have a filtering system?
Might want to pull the filter and see if somehow it got 'winterized' too. Mine had one in-line in the sink and i had to replace it.
06-06-2012, 03:02 PM
Holly Lake Ranch
It may be a combination of things
This spring when i dewinterized after putting AF in the freshwater tank, had the same foaming problem. Let it run and run but discovered if i took the aerator off the galley sink... voila... clear flowing non foaming water. Same deal with the lavatory sink.
Just let enough water run through to clear out the AF, it may take awhile.
Not sure that I will do the AF in the freshwater tank next winter.... maybe just blow the lines and put AF in the drains as the coldest we got here in DFW land this winter was high 20s
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
06-06-2012, 06:07 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I never put it in my tank. Also remove the filters prior to putting antifreeze in the system. The RV anti freeze is not poisonous like regular radiator antifreeze.
Aaron
06-06-2012, 06:10 PM
2012 25' FB Flying Cloud
Gig Harbor
Are you sure it isn't BURINE?
TAC
Hope is not a plan.
